Mystery beeps after car is locked
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Marki, Aug 13, 2014.
  1. kevtan
    kevtan Member
    Here the video
    Marki likes this.
  2. Marki
    Marki Junior Member
    I couldn't have said it better. Probably it does that to say "Hey, you! You f**ked something up and I'm not going to tell you".
    Yes, that's it! So was it the sensor error that did it?
    #22 Marki, Aug 17, 2014
    w2kpugsly likes this.
  3. mjwestrick
    mjwestrick Junior Member
    Seattle, WA
    Mine beeps six times when trying to lock it by pressing the door handle. This turns out to be because the passenger door ISN’T locking with the other doors, so it is a warning message. I can manually lock it, but the problem seems to be in the lock accuator.
    ztanos and bisco like this.
    52,863
    Nice catch(y)
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Mine did the same thing before I swapped it on both passenger and then drivers side.
  6. Bossboog
    Bossboog New Member
    St Lucia
    Does anyone have a solution to this issue?? I have the same problem when I lock and walk away from my 2012 Prius C
  7. Bossboog
    Bossboog New Member
    St Lucia
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    As mentioned in the post DIRECTLY above yours... check the car to see if it's actually locking. If it's not, your door lock actuator motors are bad and need replaced. It's a common toyota issue across the fleet.
  9. Bossboog
    Bossboog New Member
    St Lucia
    The doors are locked even when the sound comes on …sound doesn’t come on all the time when doors are locked but it comes often enough. Also it seems as if it’s coming from the front engine area. any help appreciated .
