Mystery coolant line
Discussion in 'Gen 3 Prius Technical Discussion' started by metrogtiguy, Oct 25, 2021.
  1. metrogtiguy
    metrogtiguy Junior Member
    Bradenton, FL
    Hey everyone, first Prius I've owned! I'm working on restoring it, since it was destined for a junkyard soon.
    2014 Prius Two
    105k miles
    Had a new engine installed, but it was never ran
    I began filling the coolant, and I noticed some leaking. It looks like there's only one cooling line attached to what looks like the thermostat housing. Any idea where this open line would go?? I couldn't find any diagrams that were relevant. This is on the passenger side of the car, right above the AC compressor. Thanks for the help!!
  2. metrogtiguy
    Bradenton, FL
    Found it! Looks like it's for the EGR coolant return. Part # 1626737050
    52,804
    can you back the picture out so i can look under my hood and try to find it?
  4. ChapmanF
    18,982
    The hose you want is 16267. That's the bypass return hose; it brings coolant back to the water pump even when the thermostat hasn't opened yet. You can see that the coolant returning is coming from the leg pointing down from the front of the EGR cooler (which gets there after circulating through the heater and the exhaust heat recycler) and is joined by the coolant returning from the throttle body. A fairly significant hose, all in all.
    Mendel Leisk and Ed Beaty like this.
  5. Mendel Leisk
    42,298
