Mystery hoes.
Discussion in 'Prius v Technical Discussion' started by presus, Sep 21, 2024.
  1. presus
    presus Junior Member
    33
    ny
    2013 Prius v wagon
    hello fellow toyota prius V owners. while prodding around my new to me prius clap mobile, ive discovered a few alarming things lol. one being the mystery hose. where the heck does this hose go to? i have a youtube video of it but it wont let me post the link?
  2. Air_Boss
    Air_Boss Senior Member
    4,241
    1,193
    New Yawk
    So mysterious it shall for the time being remain up to the imagination…
    Danno5060 and presus like this.
  3. Mendel Leisk
    42,220
    I’m still trying to decide if “hoes in the clap mobile” is an innocent typo.
    RRxing, Air_Boss, xliderider and 3 others like this.
  4. ChapmanF
    18,919
    Sometimes one might prefer a bit of mystery to knowing all the details.
    presus likes this.
  5. bisco
    52,740
    from what i can see, that's just an overfloes
  6. presus
    33
    ny
    2013 Prius v wagon
  7. presus
    33
    ny
    2013 Prius v wagon
    someone was even so kind as to plug the hose with a old o2 sensor!! how thoughtful
  8. Mendel Leisk
    42,220
    I can see the top end of that hose; it drops down, and can't see too far where it's going. Guessing it's coolant, and maybe headed for the Exhaust heat Recovery system? Not that large a diameter though. Could also be coming round to the throttle body (if coolant).
    Without pulling off the air box I can't really see, and I'm not that ambitious, at least not this early in the morning. Will take a look in my Repair Manual bootleg.
  9. Air_Boss
    4,241
    1,193
    New Yawk
    Sensing O2 in coolant!
  10. Mendel Leisk
    42,220
    Air_Boss and Brian1954 like this.
  11. Mendel Leisk
    42,220
    Repair Manual pic, kinda useless, but at least confirms there's two hoses involved:
  12. Mendel Leisk
    42,220
    Had nothing else happening, took some pics of our ‘10 Prius hatchback ( should be same).
    The lower hose going into the throttle body:
    is the other end of the one you show, plugged with o2 sensor. It may be cut short, require replacement.
    the upper hose coming off throttle body ends up here:
    ^ hard to see, right in middle of pic, partially hidden behind EGR pipe. It’s going into a T on side of steel pipe there:
    #12 Mendel Leisk, Sep 22, 2024
  13. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    I wonder where the liquid flows out of the fitting onto which the hose should be attached?
    Nobody has cancelled the circulation of liquid, hasn't they?
  14. Air_Boss
    4,241
    1,193
    New Yawk
    Good place for the other O2 sensor!
  15. Mendel Leisk
    42,220
    It’s two hoses, branching out to throttle body and returning. I think if OP were to remove engine air box and take a few clear photos, all would be revealed.
    basically a throttle body coolant delete.
