Mystery issue with brake lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kristen678, Aug 19, 2020.
  1. Kristen678
    Kristen678 Junior Member
    16
    Denver, CO
    Hi all -
    About a month or so ago, I received a series of warning lights (Parking Brake, ABS, and Traction Control) immediately after an oil change and an attempt by a mechanic to reset the warning light for the TPMS. Because I didn't know if this somehow happened during the oil change, I bought a code reader (VEEPEAK) and used the Garage Pro app. The code that came up is C1249, Open in Stop Light Switch Circuit. The warning lights rarely come on but the code is always the same.
    In researching the code, there were a few options for the cause such as the brake lamp switch, wiring, cruise control brake release issue, speed sensor.
    The cruise control did get wonky when this initially happened. Cruise control was activated, but not in use when the light started blinking. When I tried to reengage the cruise control, it wouldn't work until I'd turned the car off then on again.
    Today, I learned that when the brakes are engaged, only the brake light on the hatchback comes on - the other two do not. This is regardless of whether or not the warning lights are on. When I remove my foot from the brake pedal, the light goes back off (I mention that because I read that the lamp switch failure could make them stay on all the time).
    Does anyone know what is happening here?
    Thanks in advance!!
    Kristen
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Seems like there's something wrong with brake lights or wiring. You don't have a tow hitch in you're car? Or some other modification to tail light wiring? If yes check those connections first. If no mayby check for bad brake lights first.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Do the tail lights.....in the same assembly.....work when you turn the headlights ON ?
    The classic most common cause of a problem like this was a loose ground wire serving the stop lights.
    But I don't know if they depend on frame ground like they used to.
  4. Kristen678
    16
    Denver, CO
    No tow hitch or other modifications. :/
  5. Kristen678
    16
    Denver, CO
    Sam Spade - Yes! When the headlights are on, they light up.
    Is it possible that the wiring problem is happening in the area under the driver's side dash? After the oil change, the rep kept emphasizing how hard the mechanic tried to reset the TPMS (it's busted on the tire). The warning lights came on the same day.
  6. bisco
    52,886
    check the 12v neg to ground
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,129
    6,982
    Texas Hill Country
    I would check the BN Ground point in the back and the connectors at the lights
    29AE4E6E-AA29-4FAD-9D6E-4B6B84104EB5.jpeg CCFE2CF3-9851-444B-91FE-EC7614F3DD77.jpeg
    Kristen678 and valde3 like this.
  8. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Starting multiple threads on the same problem is not a good idea. Choose one of your threads to move forward on and link the other threads back to them, or ask a moderator to combine the threads.
  9. Kristen678
    16
    Denver, CO
  10. Johnphoenix
    Johnphoenix New Member
    Phoenix
    My brake lights do work. So i am not doing anything yet.
    My mechanic says if abs turns on and generally stays on and if you get either c1256 or c1391 then we should replace brake actuator.
    my abs,vsc,! indicator turned on and went away 3-4 times and the code has been c1246. My mechanic just cleared the code.
    my actuator makes that noise every 20 sec(while not driving) and every 10 sec while driving.
    #10 Johnphoenix, Sep 18, 2020
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Here is the workup for DTC C1246 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21avn/cic12464.pdf
    Notice in the above workup for DTC C1246 that there are eleven (11) possible 'detailed codes' (aka sub codes or INFs), knowing the INF for a DTC may save time and money when diagnosing or repairing a problem.
    Does the mechanic have a toyota hybrid compatible scanner that can provide the sub code(s) (detailed code or INF) for DTC C1246 ?
    Raytheeagle likes this.
  12. Johnphoenix
    Phoenix
    Sorry. I mistyped. My code has always been c1249 not c1246. It has been checked 2 times now after clearing. But every time the abs, vsc,(!), Brake indicator comes on and goes away after i stop. It comes on again at random usually in the next drive or the one after. The frequency of indicators coming on has increased. In the last 2 months i have had it come on a total of 8 times. But in the last 7 days it has come on 3-4 times. Since c1249 seems non-critical (just a abs feature that i hardly would use in a dry desert) i am not taking any action. The brake lights work like a charm.
    Would you do anything different ?
  13. Naeem50
    Naeem50 New Member
    Lahore
    2012 Aqua
    Anyone found solution?
    I have toyota vitz/yaris 2007, my car shows ABS warning sometimes, mostly when I drive on uneven or rough road. If I turn of engine and start again warning goes away. I have scanned and C1249 error comes. I have done service of brake light switch, got it replaced also but still same.
  14. rjparker
    11,129
    6,982
    Texas Hill Country
  15. Sai111
    Sai111 New Member
    Norway
    Hi kristen
    Have you found what the problem is?
