mystery needles in dash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gracie Jiu-Jitsu, Jan 2, 2014.
  1. gliderman
    gliderman Active Member
    751
    225
    What does the service department at your dealership say it is?
  2. Gracie Jiu-Jitsu
    Gracie Jiu-Jitsu New Member
    Scottsdale, Az
    I'll see if I can get some video......stay tuned.
  3. PriusInParadise
    180
    91
    Hawaii
    I believe KBeck is correct. There is likely an object similar to a toothpick or mechanical pencil lead that is rolling over the horizontal face of the display. As you state the "needle" appears after firm acceleration, I suspect the object is rolling back and forth. The mirror in the instrument cluster translates the motion to up and down. Acceleration causes the object to roll backward, and the image to rise.
    Take a small mirror and a strong light, and closely inspect the area directly below the speedometer display.
    Les_PL likes this.
  4. Grren4ever
    Grren4ever Active Member
    347
    167
    maybe stick a magnet there and try to magneto it out?
  5. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    If it's toothpick or alike it wouldn't work but it is worth to try. Or with the vacuum cleaner with narrow nozzle try to suck it out.
    Definitely the idea of PriusInParadise to inspect the mirror with the other mirror and small torch is recommended.
  6. bisco
    52,854
    should fall under the 3/36, let them replace it, problem solved.
  7. Gracie Jiu-Jitsu
    Scottsdale, Az
    I'm planning on asking next time I go in.
  8. Gracie Jiu-Jitsu
    Scottsdale, Az
    You guys, this is part of the car. It's not a foreign object; it is temperature needle of some sort. I was a mechanic for 10 years, trust me.
  9. gliderman
    751
    225
    I smell a troll. :)
  10. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    This is not part of the car. The display is a vacuum florescent display it is not capable of displaying black objects.
    John (Britprius)
  11. Gracie Jiu-Jitsu
    Scottsdale, Az
    ok you guys, I admit it, I'm an idiot! It turns out to be a small sliver of plastic. I promise to stop sniffing glue!!! Thank you all for your help and concern. :)
    PriusGuy32 likes this.
  12. El Dobro
    El Dobro A Member
    7,106
    3,282
    All is well!
  13. sosarahsays
    sosarahsays Member
    117
    37
    PNW
    Glad you solved it! I was reading through this thread and getting into a conspiracy theorist, unsolved mystery mentality!
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Mystery Solved!
    Glad it worked out...cheaply and easily.
    Thanks for keeping us on our toes. We need a post like this one, once in a while to keep us awake.
  15. The Electric Me
    9,083
    5,801
    I bet ya, it's a small sliver of plastic.
    (Too Late?)
  16. Britprius
    5,194
    1,922
    I've just gone back to sleep.;)
    John (Britprius)
  17. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    :D
