1. pasadena_commut
    pasadena_commut Senior Member
    2,954
    897
    Southern California
    This screw was found loose this morning on top of the inverter. Facing the engine compartment from the front of the car it was in the sort of trough area in the back left corner on top of the inverter. Just under the bit which holds the wipers.
    Any idea what it might be for?
    I have not done any work on top of the engine compartment in a very long time. However, I did have a mechanic change the brake fluid and try to figure out the cause of the extra 10 degrees F temperature on the front driver's side wheel several weeks ago. So it might be something brake related. It looks like there is a sort of rubber O-ring around the top of the head of the screw but that might just be carbon or dirt.
    Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    13,261
    5,357
    Pacific Northwest, USA
    I think it was a squirrel hoping if it left it there for you to see you might have a nut that works for it? :)
    pasadena_commut likes this.
  3. pasadena_commut
    2,954
    897
    Southern California
    On a more serious note...
    There aren't that many screws under the hood of a car, it is almost entirely bolts (and nuts). This looks like the sort of fastener that would attach something like a sun visor in the cabin, especially if it was accessed down a deep hole in a plastic panel. Or maybe an adjustment screw of some sort.
    It appears to be a Phillips pan head machine screw, but no idea what diameter or thread. The black stuff that looks like rubber is wear or corrosion or something like that, it isn't soft.
    #3 pasadena_commut, Nov 6, 2025
  4. pasadena_commut
    2,954
    897
    Southern California
    It seems to be a license plate screw. The ones on the front plate are a little shorter and much shinier. The ones on the back plate are the same length and finish as this one. The front plate has a "Longo Toyota" frame installed by them at some service visit in the past. My best guess is that some tech put both screws on the inverter when they put on their frame (without asking, of course), and then forget where they were, and put on new ones. The car was last in their shop 10/2020, so this screw has been riding there for 5 years. Its buddy apparently bounced out, which honestly, I am amazed that this one did not also do.
    xw20_driver and PriusCamper like this.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,315
    925
    Monument, Colorado USA
    Yes, it does look like a license plate screw! Wow, 5-years it sat there? That is amazing!
  6. PriusCamper
    13,261
    5,357
    Nice work... I knew that type of screw looked familiar!
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,535
    2,570
    Taylors, SC
    If it's a license plate screw! It would have an M6x1.0 thread.
