naphthalene inside engine bay
Discussion in 'Prius c Accessories and Modifications' started by zakky, Nov 9, 2015.
  1. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    hi friends i think this sounds funny but i do not know how to chase rats away today i installed a LED inside engine bay and i use to put some naphthalene mixing with water and i split every where inside engine bay i wants to know will it hurt to my car, if i drive the car?[​IMG][/url] [​IMG] [​IMG] [​IMG] [​IMG][/IMG]
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I cannot see the pics very well.
    Pure naphthalene is moth balls..solid at room temp.. and a minor component of gasoline
    Has some tox issues and is strong aromatic solvent may attack plastics.
    Never heard it repells mice
  3. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    That looks terrible from chemical safety perspective, to be honest.
    mertechperformance and zakky like this.
  5. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    what should i do now can i clean it tomorrow by using water in a low pressure :'(
  6. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    Peppermint oil.
    SM-G900V ?
    zakky likes this.
  7. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    will it be any problem if i wash it using water?
  8. toyotechwv
    474
    254
    Princeton, WV
    As long as you don't spray in one area constantly it should be fine. Start the car after and let it warmup and burn off some of the water. Don't soak the inverter, fuse box, or anything electrical. Don't spray with engine running as you risk sucking water through the intake.
    SM-G900V ?
    zakky likes this.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    No need to panic.
    It's a volatile material so it should evaporate, and it is not highly toxic.
    But you don't want to get into your eyes.
    It melts to liquid at about 175F
    I think if you hosed off with water, or brushed some with a broom, and let the rest evaporate, you'd be OK.
    The problem with dissolving it, is then in liquid form it might eat into plastics.
    zakky likes this.
  10. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    ok then :( i will just a hose off then it will be fine right?
  11. toyotechwv
    474
    254
    Princeton, WV
    Should be. Then get some pure peppermint oil, soak some cotton balls in it and place them in a sock or panty hose and tie that under the hood somewhere it won't interfere with vehicle operation. Should rid you of rodents.
    SM-G900V ?
    zakky likes this.
  12. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Just try not to get it on your skin or eyes, and do not breathe in the dust.
    zakky likes this.
  13. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    i have another one more question can i wash hybrid synergy drive area using water?
  14. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ..probably a good trip down the highway would evaporate a bunch just due to the air movement
    put a fan over night until it goes away
    zakky likes this.
  15. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    thanks :) i will do it with more care
  16. toyotechwv
    474
    254
    Princeton, WV
    Well, yes but, at your own risk. I have on my previous Gen 2 and Gen 3 cars. Never had an issue. Don't soak it and don't spray with direct high pressure.
    SM-G900V ?
    zakky likes this.
  17. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    :( i will try to do my best :(
    toyotechwv likes this.
  18. Mendel Leisk
    42,384
    I would use a damp cloth.
