Nav "time to arrival" always wrong
Discussion in 'Prius v Audio and Electronics' started by striker308, Aug 17, 2013.
  1. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    Has anyone else had a problem with the "time to arrival" being incorrect on their Nav system in the Gen III?
    In my Gen II I could set speed calculations for city and highway and the "time to arrival" was always within a few min of dead on.
    In the Gen III there is no setting for speed and I'm in some cases more than an hour off in the estimated time of arrival.
    I do a normal weekly trip that takes 3 hours and ~ 35 min to drive but the nav varies from 4 hours to 4 hours 15 min.
    since I drive this rout twice a week I know the correct time now but going new places I cant depend on it now when planning trips.
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    The Nav system can't account for traffic, lights or stop signs. Without MPH inputs, it bases it's time
    on known speed limits. I think it uses Google Maps data for that info. It's not a dynamic value, so it only
    uses the data that was input when the software was released. If a speed limit has changes on any of the roads
    you travel, it will not reflect in your GPS until the software version is updated :eek:
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Unless Toyota dropped the speed settings on the new Entune models, my 2010 has three different speed settings for residential streets, rural highways and interstates. My ETA is fairly accurate, especially once I get on the highway and maintain a steady speed.
  4. Zephyr7
    Zephyr7 Member
    301
    28
    Display Audio with Navigation and Entune - takes the MPH and Traffic into the ETA calculation. What it cannot predict is how much time you stop in the stop sign or how fast over the speed limit one is driving. It does not have the feature for U to enter different speed to do route ETA computation.
    The Premium Navi with HDD should still have the feature for you to enter.
    The speed limits of the road is in the navigation database, one will have to pay for an update
  5. Air_Boss
    Air_Boss Senior Member
    3,955
    1,086
    New Yawk
    On the 2012 v Five, the ETA function is reasonably accurate -- and appears to compensate for actual speed enroute, higher or lower than the "canned" segment speed.
  6. fuzzy1
    10,175
    My GenIII ETA tends initially to overstate trip times. On free flowing highway (non-interstate) without stops, I can shave off a significant amount of time. But with rest stops (more are needed when family is along), that time cushion gets used. Add congestion or traffic light delays, and the ETA understates trip time.
    My old copy of MS Streets & Trips is the opposite, its default 'average' speed understates trip time even on free flowing highways. It was obviously tuned for folks who don't obey speed limits.
  7. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    The Entune Display Audio/Nav does have the option to tweak the default speeds.
    http://www.toyota.com/t3Portal/document/omnav/OM47675U/pdf/03-4.pdf
    Page 112. right side..
    ftl likes this.
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Same settings as the 2010. Once again, if you take the time to read the manual and tailor the settings to match your driving style, the better your results and satisfaction.
  9. Worldtraveler
    Worldtraveler New Member
    That's strange. I thought they were using the Navtec database. Navtec does account for average driving time over each segment of road, and even accounts for current traffic if the installed Navigation system integrates the data (Prius apparently doesn't). I have Navtec on another car, and the driving times are typically within a minute or two over an hour's drive, and 10-20 minutes for a day's drive. Maybe they're only using some features of the database.
    I have found really strange predictions with my 2013 Prius 3. It predicted a 4h 32m driving time from Pheonix to Bell Garden CA, a distance of about 370 miles. I don't think it could be done that fast on a good day. Google maps says 5h 30m. On the other hand, I drove from home in the Phoenix area to Las Vegas last week. It predicted 4h 20m, Google maps says 4h 4m, and actual driving time was 4h 17m. Go figure.
    mtbiker53 likes this.
  10. Zephyr7
    Zephyr7 Member
    301
    28
    that manual is for Premium Navi system not the Display Audio/Nav system.
    is the date on the doc 11/09/08? Display Audio/Nav system is introduced in 2011 iirc.
  11. sURFNmADNESS
    199
    48
    Omaha, NE
    International date/time goes year/month/date
    Got my wife's 2010 map options confused with my 2012 v. 2010 base map system has speed tweak option like HDD does.
  12. Zephyr7
    Zephyr7 Member
    301
    28
    thanx silly me..
  13. Ishmael427
    Ishmael427 New Member
    I have had a similar problem with my nav and spoken with 3 or 4 different service techs and two service managers with no resolution over the last year. Mine appears to be one hour off. Sitting at the dealership today, 17 miles from home the travel time to destination was 30 minutes. When I selected the arrival time it was 1 hour and 30 minutes. It's like the system is stuck in a different time zone or doesn't adjust for change from daylight to standard time changes. No way to set time zone in the system, so I assume it is downloaded from GPS satellite.
  14. striker308
    302
    43
    Mine is still doing it, I have just learned to live with it. these cars have a mind of thier own at times.
  15. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
  16. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Computers do not do what you want them to do but what you tell them to do. Take the time to understand the user defined settings for speeds, route preferences, etc. The Nav will give you three route choices to choose from.
  17. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    Folks, we need to talk.
    This thread is in the Prius v (horribly named, but now we can deal with it) section.
    A great many of you are giving advice for a Gen 3, which does not work in the Prius v.
    If you cannot resist giving advice for other cars, PLEASE be clear what car you are giving advice for.
    I would love to set my 'time to arrive' as I did with my Gen 2, so far NO advice in this thread helps set the time to arrive in a Prius v. (it is possible the 'right answer' will be different for the 2, 3, and 5 models)
    striker308 likes this.
  18. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Sorry Jimbo, I thought with my avatar I did not have to spell out the Gen III.
    I was told in another v thread that the v has the speed settings, route preferences, etc. similar to the Gen III. Is this not correct?
    I cannot set the time of arrival directly but can indirectly with the other settings.
  19. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    I do not know, I only know that no one has reported a method for setting them on the v that works.
  20. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    In my Prius v (wagon) with Adv. Tech. Pkg, I can and have set Driving Speeds as per page 111 of Navigation Manual;
    Setup (hard key to the right of the Navi display)
    Navigation (soft key)
    Detailed Navi. Settings (soft key)
    Driving Speeds (soft key)
    Three seperate speed guages to set average driving speeds for Residential, Main Streets, and Freeways appear
    (soft keys for each guage move average driving speeds up or down)
    Remember to touch SAVE soft key or changes don't take.
    This menu option may very well only be available on Premium HDD Navaigation which is part of the Adv. Tech. Pkg.
