Navi screen displays
Discussion in 'Gen 4 Prius Audio and Electronics' started by randomwalk101, Apr 9, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Is there a way to display the Navi screen as one screen (Home) instead of the two or three split?
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I just went out and tried on mine. On the "Home" screen, I could only do a 2-split or 3-split. The only way I could get a full-screen navigation, was to press "Apps", and then Navigation.
  3. ucla107
    ucla107 Member
    98
    107
    Four Touring
    One screen only has a two or three screen option. However there is a setting (I think under general) where you can uncheck the option of "auto return to home screen" then you can keep it in the full nav screen without it going back to home all the time.
  4. randomwalk101
    532
    271
    texas
    Yeah I know. But every time you start the car it goes home.
  5. Coast Cruiser
    2,267
    2,571
    Ah, the inconveniences of life! :ROFLMAO: I remember the old days... when I kept a dirty wrinkled Rand McNally road map in the trunk.
    We will just have to press Apps and then Nav, and smile every time we pass a gas station. :D
    #5 Coast Cruiser, Apr 9, 2016
    kithmo, I'mJp and glennonrp like this.
  6. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    See ucla's post above you...
  7. randomwalk101
    532
    271
    texas
    That post *is* the reply to ucla's post....LOL
    glennonrp likes this.
  8. glennonrp
    178
    199
    Fontana, CA
    Four Touring
    Oh, ok. I thought it solved the problem. Sorry about that. Nevermind. :)
  9. ucla107
    ucla107 Member
    98
    107
    Four Touring
    While we are on the topic of the navi screen, I just noticed tonight that it doesn't have a "night" mode where the background color is black? Is that true or am I missing something? Our Lexus has a "night" mode that it switches to automatically when the headlights come on.
    iPhone ?
  10. voerman
    voerman Junior Member
    NC
    Four Touring
    If the home screen is displayed, touching the small map makes nav full screen. No need to select "apps" then "nav".
    Lou
  11. glennonrp
    178
    199
    Fontana, CA
    Four Touring
    That must be an option because it changes in mine. Time to go menu hunting!
  12. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I don't think there's a way to do that. You could, instead, just press the home button, have the nav on the left of the screen towards the driver, and tap the nav half of the screen so it will display full screen. It's not that annoying.
  13. ucla107
    ucla107 Member
    98
    107
    Four Touring
    See it stays in "day" mode... So bright and annoying
    I tried to go to the setting and according to the manual there is a way to change it but it's not available?!
    This is my option screen
    This is my version... Is there an update?
  14. randomwalk101
    532
    271
    texas
    Lower your dimmer by one notch
    ucla107 and glennonrp like this.
  15. ucla107
    ucla107 Member
    98
    107
    Four Touring
    Omg THANK YOU!!! I would've never guessed it... I literally went through all 1000 settings!
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I think that you need to have the entune app loaded and connected for update info.
    My car updated within minutes of me using the app.
  17. 'LectroFuel
    880
    673
    It should automatically switch to night mode when you turn on your headlights, but it doesn't.
  18. Tideland Prius
    16,681
    As a shortcut, if nav is one of your HOME screen displays, you can just touch the nav area to bring up the full size map. You don't have to press APPS then Navigation. (The same works for the other displays as a shortcut)
