navigation basics help please
Discussion in 'Gen 2 Prius Audio and Electronics' started by lukaczer, Jan 9, 2016.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I think my 05 was the same, I know I used it a lot.
    52,754
    hopefully the o/p will let us know.
    #22 bisco, Jan 9, 2016
  3. Andyprius1
    2,327
    859
    Cool CA
    That's how my 05 worked.
  4. Tideland Prius
    16,665
    Then you do not have navigation. The MAP button was added because it's part of the rocker button with INFO on it. That one gets you to the Energy Monitor or Consumption Screen, right? You probably have bluetooth handsfree.
    Navigation-equipped Gen 2s have 7 buttons IIRC. (DISPLAY, INFO, CLIMATE, AUDIO on the left and MENU, DEST, MAP/VOICE on the right)
    Andyprius1 likes this.
  5. Andyprius1
    2,327
    859
    Cool CA
    Finally, a accurate answer. TY
  6. Andyprius1
    2,327
    859
    Cool CA
    What happens when you push display? Or App do you get Map ? On the screen.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Why are you clogging a gen2 thread with nonsense?
    Push the display button and get controls for the display.
  8. Tideland Prius
    16,665
    Okokok.... Let's clear things up:
    Gen 4 nav: (2004-2005 Prius). Note that the 2006-2009 bezel will look the same with nav. The difference is the much higher resolution 7" LCD on the 2006-2009 models with nav. See the climate control screens below to see the difference in resolution.
    7 buttons
    2004-2005 Climate control screen. Photo credit: john1701a
    2006-2009 climate control screen (models equipped with backup camera. Non-backup camera models used the lower resolution seen above). Photo credit: john1701a
    2010-2011 Base audio. AM/FM/CD/MP3/WMA/AUX (add USB for Sept '09 build and later)
    2010-2011 JBL Audio w/ 6-CD Changer. No Nav. AM/FM/6CD/MP3/WMA/SAT/AUX (add USB for Sept '09 build and later)
    2010-2011 (Gen 6 navigation. AM/FM/4CD/MP3/WMA/SAT/BT/AUX and add a USB tab for Sept '09 build and later)
    2012-2015 (6.1" Display Audio. This does not have navigation)
    2012-2015 (6.1" Display Audio w/ Navigation and Entune App suite)
    2012-2015 (Gen 7 navigation. 7" LCD Premium HDD Navigation w/ Entune App Suite. Canadian models do not have the "APPS" button shared with the INFO button [#6])
  9. Tideland Prius
    16,665
    I do like to earn my "Prius Expert" title every now and again :)
    bisco and Andyprius1 like this.
  10. Andyprius1
    2,327
    859
    Cool CA
    That is definitely COMPLETE Thank You
    Tideland Prius likes this.
  11. bisco
    52,754
    no apps button on gen 2?
  12. Andyprius1
    2,327
    859
    Cool CA
    See TideLands
    Gen 4 Nav
  13. bisco
    52,754
    huh, thanks.
  14. silvergenII
    silvergenII Junior Member
    72
    Syracuse
    I have an 07 with nav. +1 on the garmin being better overall. That being said I can still use my '07. I rarely Need it, but just Thursday I found a discrepancy of current conditions vs 9 yr old data, the DOT had closed a cloverleaf ramp... And I was in the right hand lane when I found it torn up. Had to find a place to pull a u-turn, not fun
    #34 silvergenII, Jan 10, 2016
  15. Tideland Prius
    16,665
    Apps were introduced with Entune (later Ensuite App Suite) in 2012 on the Prius. That is also the same year that Toyota started offering more than one version of navigation - 6.1" Display Audio system from Harman Kardon and the proprietary 7" high resolution LCD screen from in-house manufacturer Denso. The Denso unit is what most Toyota owners that had navigation in the 2000s were familiar with. The HK unit on the 6.1" model is a different interface. The HK units were flash-based and quick to respond but required a USB tool from the dealer to update the maps. They also had some more modern features than the Denso units (like complete address voice input for destination compared to the Denso unit where you have to say the State, then City, then Street then House No.). The Denso units changed from DVD to hard drive. These required a USB tool from the dealer to update the maps.
    Then to make it even more confusing, starting in 2014 (or thereabouts depending on Toyota model. The 2014 Corolla was the first model to receive the new units), Toyota introduced the 8th generation units that ranged from 6.1" to 8" and started calling all their head units "Entune Audio". See attached PDF. These units are all flash-based IIRC. They're all updated via an SD card. They're also back to using the Denso interface with some changes.
    The latest units have speed limit info (US only), My Route (ability to check traffic from up to 5 saved routes), predictive traffc, and so forth.
    Gen 9 has just been released for the 2016 model year. I don't know what's new yet.
    Also, I made an error in the post with the screens so I'll clarify here (and I've fixed the post too). This is for the Liftback only.
    2004-2005: Gen 4
    2006-2009: Gen 5
    2010-2011: Gen 6
    2012-2015: Gen 7
    2016-? : Gen 8 or Gen 9. We don't know yet.
    Prius v & c
    2012-2014: Gen 7
    2015-now: Gen 8
    Andyprius1 and bisco like this.
  16. lukaczer
    lukaczer Junior Member
    Washigton, DC
    2020 Prius Prime
    Thanks for the replies- I believe you guys have nailed this-- certain prius around 06 came with the map button on the wheel but do not have nav- no nav button by the display means no nav. and no nav dvd unit under the drivers seat means no nav. Thanks!
