Navigation stinks?
Discussion in 'Gen 4 Prius Main Forum' started by dslomer64, Dec 24, 2016.
  1. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Prior to getting my 2017 Prius, I relied on Google to get me where I'm going. I say "Directions to Lane Public Library" and it gives a list from which I choose one if there's more than one, and off we go. Prius navigation? Lame by comparison? "Found" destinations are not remotely close to a library. This doesn't always happen. Prius Nav found several McDonald's (but I asked for.nearest; Google gave the nearest). Should I just forget it and stick with Google?
    RCO likes this.
  2. Prodigyplace
    12,716
    11,848
    Central Virginia
    According to many people, Toyota's navigation leave much to be desired. My son wit a 2015 Prius v that has navigation tried it a couple of times and then when back to using his Garmin GPS for his long trips.
    If he had the choice, he would not have got the navigation but it was bundled with other features he desired.
    My son's 2015 Prius v is basically a Gen 3 Prius. You have a Gen 2 Prius but posted this in the Gen 4 forum. My comments may not be totally applicable to your situation.
    EDIT2: Never mind. Your Profile lists a Gen 2 but you said a 2017 Gen 4.
    RCO likes this.
    52,863
    yes, lame. but anything would be compared to google. still, prius is pretty bad. it's okay for preset destinations, or if you have the time to input before going. but if you're off the beaten path, in a hurry, or need better info, stick with google.
    RCO likes this.
  4. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Agreed, but Just learned this, try saying open Yelp, and it will search directly using yelp. Not as good as google, but much better than using the search right at the home screen.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The one in my '13 C isn't very good but it does work.
    Try to use it a bit more and see if you can tolerate it or not.
  6. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    Overall it does have some weaknesses compared to some systems I have seen; but the Touch 2 with Go system, included with my version of the 2016 Gen 4 in the U.K., can be set up to use Google to locate destinations that are not on its database by connecting to the internet using a mobile phone's personal hotspot. You can also send planned journeys from another device to your car, using the Google Map's 'Send to Car' option.
    RCO likes this.
  7. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I have both gen 2 and 4!
    Prodigyplace likes this.
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    There is a free app for iPhone and Android phones called Waze, and it is exceptional. It's so good that Google bought them for $1 billion.
    It is very easy to use, and if you pair your phone to the car with Bluetooth, it can speak directions through your audio system.
    Bluegrassman, rcaine and RCO like this.
  9. raspy
    raspy Senior Member
    438
    699
    London, UK
    Not only is the built in Nav barely competent at best, using Google/Apple maps etc on your phone - there is so much ongoing work to refine the experience on a far more frequent basis than Toyota's system. I tried the factory nav in my Gen 4 once and then never again.
    RCO likes this.
  10. rcaine
    rcaine Member
    138
    Atlanta, GA
    2018 Prius Prime
    I was forced to get the NAV option in my 2009 and again in our 2016. I used the original one for a several years and it was far inferior to the Garmin I gave up. I started using WAZE about three years ago and have never gone back. I haven't even tried the new NAV but none of the reviews I have seen give me any encouragement to try it. Plus updates are way more expensive than buying a new GPS or even half way to a new smart phone for WAZE.
    RCO likes this.
  11. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    The last time I used my Prius Nav it tried multiple times to get me to EXIT the interstate by directing me to drive the wrong way up an ON RAMP! Haven't used it since. Just Google and/or Waze now
  12. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    This is why we need CarPlay and Android Auto! Please, Toyota, please!
    abensky likes this.
  13. Prodigyplace
    12,716
    11,848
    Central Virginia
    How would these improve the built-in navigation? That is the topic of this thread.
  14. 'LectroFuel
    880
    673
    It won't. It'd be an alternative that doesn't involve using your phone.
  15. Prodigyplace
    12,716
    11,848
    Central Virginia
    I thought the whole point of Android Auto & CarPlay was to use your phone. for streaming, navigation. etc. as an addition to other manufacturer installed features such as navigation.
    Some cars support both Apple CarPlay & Android Auto. Are you saying those cars have two built-in navigation systems, one for each platform?
    RCO likes this.
  16. 'LectroFuel
    880
    673
    CarPlay uses your phone, which is plugged into the USB port, to do different things like nav, streaming, and calling. It's handsfree with the holding of the voice control button on the steering wheel (or holding the home button on iPhone) to get Siri. CarPlay has Apple Maps and Android Auto has Google Maps. Some cars like on Hyundais have both systems and therefore have two nav units. They have more navigation options than Toyota. It's another reason to go with the IONIQ.
    RCO likes this.
  17. greenmonster01
    106
    79
    Southeastern MA
    I just assume that all oem navigation solutions suck. Once they get a few years old, especially w/o expensive oem map updates, they suck even more...
    I've always believed that any oem navi hurts resale value...
    <--- garmin offline maps on iOS user
  18. Rebound
    3,996
    2,645
    Portland, OR
    The OEM GPS is a joke. I think by now everybody knows it, but they can't sell a car without it. I was always hoping that car makers would just adopt MHL, so your phone screen would appear on your car screen, and you'd always have the latest technology on your dashboard. It would have been simple and inexpensive.
    abensky and RCO like this.
  19. Prodigyplace
    12,716
    11,848
    Central Virginia
    That's funny. I thought I purchased my Trim Two with no GPS.
    Where is the hidden menu?
  20. Rebound
    3,996
    2,645
    Portland, OR
    Ha ha.
    Truth is, all the midrange models and up from every carmaker have GPS, and it's always awful.
