Navigation stopped working ??
Discussion in 'Gen 2 Prius Audio and Electronics' started by aaction1, Apr 30, 2012.
  1. aaction1
    aaction1 New Member
    Lubbock,Texas
    2003 Prius
    I have a 2005 Prius the navigation system stopped working. When I press the Map button, the screen displays "the external system is not connected" also the voice came on and said voice recognition is off. Could it be a fuse or need to reset? It was working fine then just went black. I restarted the car a few times but still no work. Also where is the player at on the 05? any help..
  2. aaction1
    aaction1 New Member
    Lubbock,Texas
    2003 Prius
    working today for unknown reason.. oh well all's well that ends well
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. Cheri L
    Cheri L New Member
    Tucson AZ
    Four Touring
    My navigation system stopped working about a year ago. It displays horizontal white bars when I click on map.
    Everything else works, audio, climate, etc.
    Once in awhile it will work (for 2-3 days about once every 6 months).
    I have been searching for others with this problem.
    The dealer says I need an entire new unit.
    The toy shop says the cannot fix it as only dealers can.
    Ideas, thoughts, suggestions?
    Manny - AZ likes this.
  5. bisco
    52,803
    try steve at autobeyours.com, he may rebuild them, not sure.
  6. Manny - AZ
    Manny - AZ New Member
    Arizona
    I just finished my hybrid battery rebuild and took it for a test drive. I noticed the same issue. Curious if you found a solution.
