navigation update
Discussion in 'Gen 2 Prius Main Forum' started by prepb18, Oct 28, 2012.
  1. prepb18
    prepb18 New Member
    atlanta, ga
    i have a 2005 prius that is in major need of a nav update. I just called the dealer, and they mentioned that the newest version is arriving on nov 1st ($169) and that the current version is on sale ($139).
    Should I save the $30 with the older version or go with the newest one? Thoughts?
  2. Patrick Wong
    18,210
    6,526
    Well - my thought is that you should use the money to buy an add-on GPS unit that will have a more accurate map and probably offer lifetime map database updates at no additional charge.
    However if you must continue use of the factory-installed GPS, then it's up to you whether the $30 savings is worth your having to use the older map database.
  3. prepb18
    prepb18 New Member
    atlanta, ga
    Hmm, that's an interesting perspective. I use my iphone for the addresses the nav can't find, I just prefer the sleekness of the in-dash system.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Ask the dealer for the update information for each of the updates. It will give you the details of the changes state-by-state. Then you can decide if the latest update is worth the $30.
    I am like you that I like the built in GPS over external devices and cables. The Toyota GPS can't match Garmin features but mine has always gotten me from point A to B.
  5. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    If you get the older version how will you feel the first time that you have an issue with it being outdated?
  6. Wimble
    Wimble Junior Member
    30
    uk
    You could view this in a couple of ways - you can offset the high cost for the update of an average to good inbuilt system to maintain the current cabin "look". Or buy a cheaper, arguably better off the shelf GPS unit that you can update at your leisure/cost and which is transferable to a new vehicle or can itself be sold if no longer required. Also, if you are going to update at the full cost, you may as well go with the top spec available, or it negates your very reason for wanting accurate maps. Just my opinion. :)
