Navigation Volume Adjustment?
Discussion in 'Prius v Audio and Electronics' started by btcompute, Apr 14, 2012.
  1. btcompute
    btcompute Junior Member
    46
    Central NH
    Has anybody found a way to increase the volume for the navigation prompts? It would be nice to make them a little louder.
    Thanks.
  2. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    I know you can under settings for a default volume and I've also used my volume control on the steering wheel as needed. I have the display audio which is the radio in a v without the advanced tech package. W
  3. Midpack
    Midpack Member
    461
    43
    Chicagoland
    It took us a little while to figure it out, it's a button on the nav screen that looks like a speaker (lower left IIRC). Push it and it will let you adjust volume...
    Ours came with volume on very low. We were surprised that the nav system doesn't mute/reduce radio volume automatically - like our 5 year old 2007 TCH. But now with the volume turned up, it's workable. Bluetooth phone quiets the radio, but nav doesn't ???
  4. btcompute
    46
    Central NH
    Thanks Midpack. That did it. Now if only I could find a voice command to cancel a route...
  5. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    If you do...let me know...!!!
  6. OWG
    OWG Junior Member
    86
    16
    Barrie, Canada
    x 2!
  7. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    46
    Crystal Beach, Texas
    As far as I know there isn't one. You have to hit options and then select stop guidance.
  8. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    That's almost as good.....Thanks..!!!
  9. Arizonaguy
    Arizonaguy New Member
    Just click the RPT (Repeat) button below the screen and while the voice is repeating the directions, you can then easily adjust the volume.
