NC machine shop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EzC, May 5, 2026.
  1. EzC
    EzC New Member
    Durham
    2014 Prius v wagon
    Going to embark on the journey that is head gasket replacement on a 2013 gen III Prius. In need of a NC machine shop to get the heads machined though.
    Any recommendations? RDU- Greensboro- Charlotte and thereabouts recommendations welcomed.
    thank you
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    It'll probably be cheaper to find on eBay already all done in a bag ready to go . That was same for my 1zz. The shops here in Durham and Central North Carolina most of them seem to be closed. I don't know if Thoff is still in business in Raleigh. But rather than look for machine shops I went to eBay and found a machine shop that sells heads complete . About 400 with cams all set and adjusted . I'd spend that on my head . Included shipping.
  3. Mendel Leisk
    42,348
    I’d check against specs with a mechanics straight edge first; would only machine as a last resort. See last link in my signature (on a phone turn it landscape to see signatures).
    what’s the miles?
  4. EzC
    EzC New Member
    Durham
    2014 Prius v wagon
    Sorry for the late response, it's at 230k miles. Haven't removed the head yet but once the gasket kit & other assorted parts that will be on the menu. I was assuming that I would have to get them machined so was hoping to get ahead of it, not sure of Toyota's opinion on it though. Even if the heads were within spec should I still look into getting the valves lapped or stem seals done? Read part of the critic's thread. Is general sentiment just measure if within spec and send it?
  5. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    The valve guide seals come in the FULL gasket kit, from Toyota.
    Not that hard to change them.
    You can check if the valves are leaking by spraying some wd-40 into each intake and exhaust port
    with the head flat. Wait 10-15 minutes then slowly lift the head up and see if you see any fluid.
    If not, you're good to go. If any are leaking, go ahead and lap them in.
    Since you have to remove the spring to replace the guides. You should always check anytime the head
    is off. It doesn't require any special tools.
    But if you don't want too, and no leaks at any of the valves, you will probably be fine.
  6. Tombukt2
    13,863
    2,519
    Durham NC
    Usually I've been able to order a head all done up with cams free adjusted everything all set ready to go about 435 delivered to. Me .. I can't do better locally not anymore most of the machine shops are closed up they're hard to find.
    EzC likes this.
