Near Center Speedometer....Again?
Discussion in 'Prius v Main Forum' started by Rest, Jan 11, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    My memory could be wrong/bad but I could've sworn there was discussion of an optional HUD on JDM (?) 2nd gens.
  2. Tideland Prius
    16,675
    Time to ask Ken lol
  3. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  4. Tideland Prius
    16,675
  5. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    I think the center stack makes it easier for Toyota to change to left or right drive, depending on where the order is headed. All Prii are still made in Japan (as far as I know) so there is less re-tooling for the factory with center speedo.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    So that's where this is going? There are left and right hand drives of many cars - Civics, Accords, Corollas, Camrys whose gages are in front of the driver, where they belong.
    I do not see one Honda model with speedometer near the middle. It seems Toyota picked this idea up from their Scion brand. Why do passengers need to see the speedo?
    I have no problem seeing my speedo / tach through the steering wheel as 'we've' been doing for who knows how many years. Heads up speedo is fine too, in front.
  7. Tideland Prius
    16,675
    Not to mention, aside from the Gen 1 Prius, the instrumental panel is offset.
  8. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Oh I WANT those analog guages!
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    As Tideland said as well, in 04 -09 Prius, the digital speedo is nearly centered in front of driver. In 3rd gen, it is perhaps 6" further to the right.
  10. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Actually, Toyota had been doing this before the Scion brand even existed. Scion (automobile) - Wikipedia, the free encyclopedia says the Scion brand was founded in 02.
    When I first went to Japan in late 2001, I saw some JDM Toyotas at the Toyota Amlux w/speedos in the center. Some of them later were rebadged as Scions for the US market.
    Also, the NHW11 Prius had the speedo in the center along w/the Toyota Echo, both of which predated Scion.
  11. toronado455
    toronado455 Member
    179
    22
    Southern California
    The use of mirror(s) has always been my objection to the Prius dash. The horizontal positioning makes no difference to me.
    From the pics I've seen, the Prius V seems to be the first Prius to eliminate the mirror(s) entirely, which, if I'm correct about that, makes it the first Prius I'll seriously consider buying.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You won't buy a Prius because of the reflective speedometer? :confused:
  13. toronado455
    toronado455 Member
    179
    22
    Southern California
    I strongly dislike the double image.
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The double image is only offset by the thickness of the glass panel. The distance you sit from the cluster is so much greater than the thickness that it is barely noticeable. Seems really silly to not buy an entire car because of a millimeter of refraction. I can see that being one point of many, but that being the deciding factor is just mind boggling.
  15. ashp
    ashp New Member
    Peterborough,Ontario
    I'm 6'5" and am constantly rubber-necking to see the gauges thru the steering wheels of my other vehicles. The centre mounted instrumentation in my new prius v has been an unexpected blessing.
  16. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    Much the same thing for me as well - although I am not quite as tall (only 6'). I find that the central location of the instrument cluster does not seem to be a problem at all.
  17. Tideland Prius
    16,675
    A centre-mounted set of gauges mean a smaller steering wheel too. Our Camry's regular-sized steering wheel feels gigantic compared to the Prius' wheel.
  18. Flyman
    Flyman Junior Member
    64
    Packwood, Washington
    :rolleyes: My wife and I both like the center display. Pretty simple stuff here, if you don't like it, buy a different car. :)
  19. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    I drove my wife's Honda CRV the other day, and it seemed to be a conscious effort to take my eyes off the road to see the speedo. I believe the Prius version to be safer and not noticeable after a few trips.
  20. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I can't speak for the v exactly but my '11 has nearly center gages. They don't bother me at all. In fact one benefit is I can show passengers what is going on with the car more easily. I especially like to show the gage with the car, gas and electric engine and how it all works together. These are exceptional cars, especially since my avg. economy is over 55 mpg at 250 miles into this tank. It's actually a more practical car than the Accord Couple I traded in and it gets over twice the average fuel economy. I like that! :cool:
