Nearside rear window goes down only
Discussion in 'Gen 2 Prius Main Forum' started by james909, Sep 22, 2023.
  1. ChapmanF
    19,002
    My Hall clamp is made by Fluke, no shabby name, and it too is finicky about zeroing in the lowest amp range, and also never quite gets there. Seems to be the nature of the beast. I'll often flip it around and average the two readings.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    True enough. Plus there's drift due to temperature change.
    I've got a bunch of amp clamps for diagnostics. Pico, Snap On, AEMC, Amprobe. The ones with physical adjustment knobs I can understand being off zero some when you power on (depending on what the range & temperature was previously).
    The ones that have a "push button" zero function usually are at zero when turned on. The Uni T always has an offset when switching to DC amps (just checked - right now it's 0.341 amps & is the same on all ranges)
    I can zero it by pushing a button, just find it odd that I have to.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,038
    943
    Southern California
    Exact method was:
    1. set it to 2A range, DC mode
    2. clamp around the rubber hose on the hinge side of the door
    (this part didn't work well, the clamp closed, but not convincingly so)
    3. zero button (verify that the display is at zero)
    4. press switch and measure
    Normally I zero before clamping, to measure the current already running in a wire, but in this case I wanted to zero any small one way current into or out of the door that might have been present before the door switch was enabled.
  4. pasadena_commut
    3,038
    943
    Southern California
    Could be a cost saving measure in the design.
    The meter must always be zeroed before the last slight displacement to apply the clamp, so that whatever extraneous magnetic fields which are around don't throw off the measurement. So why add circuitry to zero it once at a random location in space, which is probably not the proper place to do that operation? At least for me, I usually hold the thing up in front of my face so that I can read it better when changing modes. The screen is pretty reflective, I'm often wearing polarizing sun glasses, and it has to be held just so so that I can read it clearly to verify that it is in the right mode.
    If I had to design that circuit, on entering DC clamp mode it would show XXXXX or DOZERO or some other flag to indicate the unit was not yet zeroed. I wouldn't set it to 0.000 because the naive user might not then zero it properly when placing it for the measurement.
  5. james909
    james909 Member
    107
    Leeds, U.K
    I thought I would update you. The second rear window has just failed and is now taped up. I'm wondering if this is a common issue. I was using the master switch. Put the windows down to let in fresh air. Tried to put them all up and one wouldn't move.
  6. james909
    james909 Member
    107
    Leeds, U.K
    Found the problem. Took the master switch apart. The pegs on the underside of the buttons have snapped so the levers on the circuit board were stuck in the down position. It's a rocker switch which moves a lever on the circuit board forward and backwards with a neutral position in the middle when not operated.
    Brian1954 likes this.
  7. pasadena_commut
    3,038
    943
    Southern California
    Can the pegs be repaired? Blob of JB Weld (or equivalent) and some filing? I'm sure you could get the switch off another car in a junkyard, but it would be roughly the same age, and the plastic pegs on it would be just as brittle.
