Neat and Obscure facts about the PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Apr 18, 2012.
  1. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    You either play around a lot with your PIP or you get really deep into the manual.:sleep:
    Kit Shah likes this.
  2. 3PriusMike
    3,100
    2,419
    Silicon Valley
    No...I just discovered this by plugging in to the car first. LED came on. When plugging into the wall first it didn't. Then I just pressed the latch button and noticed that the LED went off. No reason to not want to save 1/2 watt or whatever.
    Mike
  3. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    I really want a bigger battery...
    chesleyn likes this.
  4. DLee
    DLee Junior Member
    81
    CharlesH, you will appreciate this: A European automobile manufacturer used to call these symbols "idiograms".
  5. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    Can we have anymore input on this tire inflation? Whatever the dealer put in my Prius is what I got now.. Never check it. Should I?
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Religiously if you care about tire wear, mpg, and safety!
    Set them at 38/36psi at the coldest part of the day and you should be fine. Check it monthly at least. Readjust pressure as summer sets in. Remember, pressure is affected by air temp. Pressure changes by 1psi for every 10F change in temperature.
    Tire Tech Information - Air Pressure, Temperature Fluctuations
    Tire Tech Information - Air Pressure: When and How to Set
  7. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Some of us set them even higher...up to 44/42 psi.
    It should be noted that the tires are generally rated for 50 psi. This means 50 psi with a gauge that is off a little and when cold, then you drive for many hours in desert heat so the actual psi is much higher than 50 psi.
    In the summer if I am going to drive on a long trip I lower the pressure 2-3 psi. If I'm in 100F heat driving far I also check them when getting gas.
    Mike
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Most of the OE Prius 15" tires are rated at 44psi cold. One of the Fuel Max tires (H rated) is rated at 51psi.
    lensovet likes this.
  9. lensovet
    2,615
    496
    Burlington, NJ
    Pretty sure the reason they do this is not PC (I mean, really???), but cost savings. With pictograms, they can have the exact same levers go into every car worldwide.
  10. Bonefish Blues
    98
    31
    Oxford, UK
    The UK PiP has different modes to the US one. We have Eco, HV/EV and EV City modes. No Power (although that's on regular Prius).
    Oh and hi from the UK!
  11. bisco
    51,950
    hello, and welcome!:)
  12. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Hello.
    We'd like to know more about the EV CITY mode.
    We got the impression it offered even more power than regular EV mode here but the tradeoff was a slower max speed.
  13. Bonefish Blues
    98
    31
    Oxford, UK
    I'm not sure that's correct based on my experience. I think neither of the UK EV modes offer your top speed in the US - my tipping point is an indicated 58mph (true 54 or so) at which point the ICE cuts in. Whether we get more power on demand than you do as a trade off, I don't know, but doubt, TBH.
    Interestingly, this is higher than Totota states - they say 51mph, but quote the same EV range. Here's the UK-spec brochure with our single trim level, which seems to be a hybrid of yours, if you'll excuse the phrase: http://www.toyota.co.uk/bv/leads/pdfFiles/rc66534.pdf
    AIUI the EV City mode just allows you to use wider throttle openings before the ICE kicks in - certainly in EV City the initial liveliness very soon gets suppressed and gaining speed over say 45 is soooo painful that you'd want to change mode anyway. A sharp jab on the throttle will override and cut in the ICE, though - it's just much harder to do than in regular EV.
  14. CharlesH
    2,797
    1,163
    Roseville, CA
    As I understand it, "City" mode is there to allow the PiP to be used in "zero emissions zones" in some European cities.
  15. lensovet
    2,615
    496
    Burlington, NJ
    right, and so it lets you "floor" it harder than plain EV mode without kicking on ICE. I really wish we had this mode instead of the power mode.
    delrey likes this.
  16. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    When you first boot the car, you can't change the radio volume for a couple of seconds even if you can already hear the music. So when the music is too loud, you actually have to wait around 3 seconds before you can begin to lower the volume. My Gen II Prius was responding much faster to the volume button during the Prius boot sequence.
  17. bisco
    51,950
    that doesn't qualify as 'neat'.:p
    lensovet, Kit Shah, F8L and 3 others like this.
  18. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    No but it's definitely "obscure" ;)
  19. bisco
    51,950
    you got me there!:cool:
    Drake likes this.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It qualifies for the use of another four letter word I use every time it happens. :)
    Tideland Prius, lensovet and Drake like this.
