Neat and Obscure facts about the PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Apr 18, 2012.
  1. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    Found this out while pluged into a charge port 220 station the other day...
    If you are charging on 220 and are fully charged then turn on the A/C remotly, the A/C draw is less then the charge rate, so when you turn off the A/C and unplug the car you will be at 100%.
    But on 110 I have found that letting the A/C run for 5 minutes remotly after being fully charged will require about 10 minutes to top the battery back off after the A/C is shut off.
    MarkPressey likes this.
  2. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I have an L2 charger and after fully charging then turning on the A/C remotely, it charges another 10 minutes after the remote A/C turns off.
  3. Totmacher
    301
    110
    Mission Viejo, CA
    wow, i let mine go the full 10 minutes. Mine is in a parking garage so maybe the compressor does not have to work hard enough to overlap the 220.
  4. elife
    elife Junior Member
    37
    Northern Virginia
    Ultraturtle - or anyone - so Toyota makes a donut spare, with a cover, for the PiP? If so it would probably ease my mind to have it in the car on long trips only - other times would just leave in garage....may be better solution than "fix a flat" that comes with the car....at least you can use the donut to get you to the repair shop.
    Rob
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I could be wrong, but I think Ultraturtle just put their own in with a cover on it. I am unaware of Toyota making one for the PiP as there wouldn't be a place to store it anyway other than strapping it down to the rear cargo deck. It's easy enough to just get your own donut spare, get a cover and strap it down, and cheaper than buying one from Toyota anyway even if they did offer one.
  6. elife
    elife Junior Member
    37
    Northern Virginia
    Thanks Mark - what size "donut" tire (and rim) would I get? I guess not all donut tires and rims are the same size? Sorry - just never been in the "donut" tire market before - but welcome the POM (peace of mind) for longer travel events that having one in the car would provide.
    Rob
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Not quite sure to be honest, but start a conversation with ultraturtle and ask what they went with (a conversation on here is like a PM on most sites, the forum upgrade changed the name).
    I found this post from ultraturtle showing a pic of their setup, they put it behind the drivers seat. No spare tire? | Page 6 | PriusChat
    Edit, a few post down in that thread ultraturtle says
    They also say where and how much to get the tote for to cover it in the linked thread.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    I bought a 125/70/d16 from a late model Corolla, bolts on just fine. $35, at least it will get me to town to get the orginal tire fixed.
  9. elife
    elife Junior Member
    37
    Northern Virginia
    Thanks all for the spare tire info - I will start my search
    Rob
  10. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    For anyone who cares, the new AT&T mobile share plans include wireless (wifi or bluetooth) hotspot as part of the package price. We had 2 iphones on a family plan with 550 shared minutes, unlimited texting, one 300MB and one 3GB data package. New plan is about same price for unlimited talk and text, and 4GB of shared data which includes hotspot so we can finally run the ipad/laptop off the cell data without paying extra.
    Rob
  11. ultraturtle
    108
    81
    Peachtree City, GA
    Thanks Paradox, for looking that up. I would also recommend you purchase a spare from 2010 or newer (Prius, Corolla, Matrix, or Scion), as spares prior to that have a slightly smaller diameter, and might unduly stress your drivetrain. Another reason to get a more recent model spare is the life of the rubber. It deteriorates over time, and (unlike your main tires) may need to be called upon for duty for the useful life of the car.
    Also, on CrewDog's suggestion, I put the spare on the right rear floor so as not to block the battery vent. That location has the added advantage of better weight distribution and frees up the left rear seat for more storage.
    Finally, I'd recommend you secure the spare to the vehicle to reduce risk of injury in a collision. Mine is tied with a rope looped around the right rear bench seat attach point, and through the lower two spare bolt holes. Make sure to get your hands as close as possible to the front hook before pulling up, so as not to deform the seat cushion frame:
    I stuff a small compressor (10 amp max - I learned the hard way), plug kit, trash bag, nitrile gloves, and hand wipes in the cavity created between the spare and the seat, so everything is ready to go for a quick repair or tire change.
  12. markabele
    5,084
    1,782
    Nebraska
    What on earth does this have to do with the PiP? Please tell me your account was hacked by an AT&T executive.
    radiocycle and priuskitty like this.
  13. miscrms
    2,079
    526
    Phoenix, AZ
    Earlier in the thread it was noted that the PiP Entune system could be set up to use an iphone's cellular internet connection via bluetooth, instead of having to plug it in every time. It was discussed that the downside to that is you had to pay $20/month extra to AT&T to enable this capability on an iphone. Just updating that conversation for those who want to use this feature but not enough to pay $20 a month for it.
    Rob
  14. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Good to know, thanks
  15. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    I couldn't. A person I spoke with at Entune said the iPhone 5 needs to be plugged into the USB port. I do however, use Bluetooth to play music wirelessly most of the time. I don't care much for Pandora. I use Verizon.
  16. CarmelPrius
    49
    Maine
    I guess I do too, but it took me forever to use the proper buttons. I kept screwing up the radio station before getting it right. I thought my wife was going to throttle me. :)
  17. lensovet
    2,615
    496
    Burlington, NJ
    yes you can
    see the FAQ
    to answer the pricing question: Tethering on AT&T requires enrollment in the 5 GB data plan, which is $50/mo. alternatively, you can sign up for one of the new Mobile Share plans, which include tethering "for free".
  18. bisco
    51,937
    i didn't know until yesterday that this was obscure, but apparently, some here don't know that there are two different ration screens and you can toggle back and forth by pushing the display reset and reset them separately by holding down reset for the ratio screen you are viewing.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah....go ahead....rub in in:p
    lensovet likes this.
  20. mrbigh
    3,686
    699
    Long Island, NY
    Oh BISCO. I think that this explanation needs to be expanded for this old fart.
    What ratio and reset screen are you referring to?
    The conversation before yours was related to tethering on the iPhone and their wireless service. Thank you
    dmaxwellh likes this.
