Necessary maintenance at 120k?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by xna, Dec 30, 2015.
  1. xna
    xna New Member
    Boston, MA
    I'm looking for some guidance on what maintenance I should get done on my 2005 prius. At 98,706 I had the rear brakes cleaned/adjusted, and I recently got two new rear tires. I haven't gotten any fluids flushed ever except when I had both water pumps replaced (one recall, one broke. apparently priuses have two?). I have no idea what I need. I've been reading up around here and this is the list I've come up with:
    • Brake fluid flush
    • Transaxle fluid
    • Fuel injector cleaning
    • Throttle plate cleaning
    • PCV valve replacement
    • Oil Change
    • Tire rotation/alignment
    Am I missing anything? Any idea on how much this would cost me?
  2. JC91006
    16,939
    8,647
    How long have you owned this car? Most of those items you can do yourself and minimal costs. If you take it to a shop, I would say about $300.
    If you're not having any driving issues, I probably would start with just doing a transaxle fluid change and spark plugs change. Oil change is every 5000 miles
  3. NHsky01
    NHsky01 New Member
    NH
    I
    We took our 2008 Prius in with 95,000 miles on it and these were recommended:
    coolant service
    transmission fluid changed
    new drive belt
    spark plugs
    The car has had it's oil changed regularly. I've replaced the 12V battery, the Big Battery still works fine.
  4. xna
    xna New Member
    Boston, MA
    I bought it new in 2005. I don't have access to a garage, otherwise I'd do it myself. Thanks for your advice!
  5. xna
    xna New Member
    Boston, MA
    Did you do all of this? Thanks for your input
  6. bisco
    52,923
    i think you're due for plugs, belt, (might want to change the water pump at the same time) and fluids. oil and all filters of course.
  7. xna
    xna New Member
    Boston, MA
    What do you mean by belt? Why would I need to replace my water pump again? And which one?
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    There's drive belt that turns the water pump. If its the stock belt its way overdue for replacement. If the belt breaks it really gets you good. The water pump stops turning and you'll never know it till the engine overheats and throws a overheat DTC. By then its usually to late and engine damage results.
  9. bisco
    52,923
    if you've already done the water pump, no need, it's just easy when the belts off. maybe they already replaced the belt?
  10. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    When both coolant pumps were changed, it's possible they recycled the old coolant back into the engine. (That's what they were going to do on mine, so I specifically asked and paid extra for new coolant--not cheap.) So you might need coolant changed in both systems.
    If the throttle plate/body gets cleaned, I'd do the MAF sensor too. Neither is high on the list unless it's running rough.
