Need a 2005 Prius ABS Module Actuator Pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brett Martz, May 31, 2023.
  1. Brett Martz
    Brett Martz Junior Member
    Ohio
    I am getting codes C1252, C1256, C1391. I believe the actuator pump needs changed. Replacement seems straightforward enough. Where can I get a good replacement at the best price? Online ranging from $400-$1,000?!? I have 163,000 miles on the prius, lifetime warranty on a hybrid battery replacement that went in at 100,000. Other than that have not had any issues. Any help is appreciated. Trying to get my truck back in the garage and the prius back on the road. Gas prices will make up the difference in part cost soon!
  2. JC91006
    16,673
    8,518
    The replacement is quite time consuming and may take you up to 5 hours to do this. Also when you're done, you'll need a computer software to bleed the brake system for you.
    It may be best to buy a new one, a used one can fail like yours did. Not sure that's worthwhile with that much labor involved
  3. Maloose
    Maloose New Member
    I just did this --it took me a long time but it can be done...I'm going to make a post about it soon
  4. BrokenPipe
    BrokenPipe Junior Member
    34
    NorCal
    Go to your local salvage yard for the best price on all the parts you need. Around here it's the Pick-n-pull. Also wait until they have a 50%off sale on everything if you can wait. Though that's not always possible.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    You pays your money and takes your chances.
    You already have a used part -( that's likely bad.) Why should another used part be much better? I have read that some have good luck doing this, others not so much. Maybe the replacement part still has pressure leakage, or noisy pump, or cannot relearn the linear solenoid offset.
