Need a fast response. Just finished balancing my hybrid battery and have a question.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rugtol, Mar 9, 2020.
  1. rugtol
    rugtol New Member
    Portland
    I just finished charging/discharging all 28 modules and balancing them so the voltages are the same. each one is reading at 7.32 volts. It is a little low because it took me a long to time do them all and some sat for a while. I was wondering if it is ok that these are this low? From what I understand they all just need to be the same and the voltage level doesn't necessarily matter?
    Should I top them all off or is 7.32 volts fine and the car will bring them back up once I put the battery back in?
  2. JC91006
    16,919
    8,634
    1. What equipment are you using?
    2. If you fully charged the modules, if they are healthy modules, they shouldn't reach 7.32 volts for months by just sitting
    SFO and Raytheeagle like this.
  3. rugtol
    rugtol New Member
    Portland
    For some reason I can't get the amazon link to properly format. This is a copy of the item name.
    SKYRC B6 AC V2 50W LiPo LiFe LiIon NiMH NiCd Battery Charger Discharge
    I've read that they slowly discharge while sitting.
