Need a more comfortable ride.
Discussion in 'Gen 3 Prius Main Forum' started by KLS24, May 30, 2026.
  1. KLS24
    KLS24 New Member
    Providence RI
    Hi. I just bought a 2012 Prius Four. It had snows on it so had mechanic put on new tires. Now car rides terrible. So today I had a separate tire shop balance the tires and do an alignment. Still doesn't ride very well. I feel every bump. Is it just the car itself or could something be wrong? It rode better on the snows. Should I get better tires?
  2. ChapmanF
    19,060
    What tires did you get?
  3. JC91006
    16,939
    8,647
    Feeling every bump can be a sign of bad suspension parts. Also the 17" tires will not ride as well as a 15" tire. So you can try downgrading to a smaller tire with a bigger side wall
  4. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Did you check the tire pressure?
  5. bisco
    52,904
    congrats and welcome!
    how many miles on her?
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I'm sure the shocks are dead.....
