Need advice for a long trip without access to charging.
Discussion in 'Prime Fuel Economy & EV Range' started by mistermojorizin, Jun 19, 2019.
  1. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Lots of good advice already, but I like to keep my driving rules simple:
    EV = In-city and/or during stop and go on the highway
    Eco/HV = Driving at highway speeds
    I also don't bother with using B mode unless I'm going down a really (really!) long mountain/hill. The normal braking seems to do a good job of recharging, as long as you keep it at light braking rather than hard braking. From my experience with Hybrid Assistant, light braking regens the battery, hard braking uses the brake pads.
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Similar here. Just keep the HSI indicator from hitting the end of its travel on the "Charge" indicator and there should not be friction braking.
  3. jerrymildred
    11,517
    14,167
    Tampa, FL
    Conservative helps, but where did that 15 mile EV range come from? 25-35 is typical. And it can make a huge difference when managed properly.
    Roy2001 and Blauer Glimmer like this.
