Need advice for my Prius
Discussion in 'Gen 2 Prius Main Forum' started by Shoefoot, Sep 24, 2021.
  1. Shoefoot
    Shoefoot New Member
    Maryland
    I need some advice about my 2007 Prius. A few days ago some of the dash lights randomly came on while driving (ABS, VSC, ! brake light). After shutting the car off for several hours, I checked again and the lights were off and haven't came back on. The same thing happened a few months ago. When I let off of the gas or brake pedal there is a weird popping/clunking sound that I have noticed for several months now. I'm not in a situation where I can afford a costly repair. The car already has 211k on it. Is it likely that whatever caused the dash light issue will keep happening or could it have been a random event? I'm trying to decide if I should keep it another year until it's paid off or just trade it back in now before the problem gets worse.
  2. burrito
    burrito Active Member
    274
    114
    It's not likely to be a random event. If you keep it for another year, it'll have another year of problems. What's it worth to you for it to be paid off? How much can you get for it if you traded it in now?
    #2 burrito, Sep 24, 2021
  3. Shoefoot
    Shoefoot New Member
    Maryland
    I'm going to the dealership Monday to get specifics, but by my guess they're probably not going to give me enough to pay off my loan. I owe approximately $3500 left on it and by KBB trade in value it shows $2200-2500, so probably less than that is what they will give me. I agree that another year will probably just bring more problems. I'm a college student with not a lot of money so I definitely can't afford to fix something really expensive, but I need something reliable to get me to class.
    52,847
    have you cleaned the egr circuit?
  5. Shoefoot
    Shoefoot New Member
    Maryland
    I have no idea what that is, so I'm gonna say no lol
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    None present on the Gen2;).
    Sound advice if it were a bit newer(y).
    Mendel Leisk, SFO and bisco like this.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
  8. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Can't make any recommendation until you have ALL the modules in the car scanned with a compatible scantool to retrieve codes.
  9. bisco
    52,847
    it was a trick question, you guys ruined it
    Mendel Leisk and Raytheeagle like this.
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Sorry for raining on your parade :sneaky:.
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    When was the last time the inverter coolant pump was replaced?
    Just a WAG, but this sounds like a DTC P0A93. The next time this happens see if the AC is working properly.
    You can also check for turbulence in the inverter coolant reservoir, and or feel the pump housing for vibration using a finger/stick/rod/pencil.
    Going forward, best to use a hybrid compatible OBD2 scanner to retrieve the codes (DTCs), then post them here for additional guidance.
    Raytheeagle likes this.
  12. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Well, I'm sure the problem (whatever it is) is SOMEWHERE between the front and rear bumpers...
