Need advice on front wheel hub replacement
Discussion in 'Gen 2 Prius Main Forum' started by Aegean, Sep 30, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    For Your Info FYI//For What Its Worth FWIW (this mechanic is always rock solid on all repairs)
    Wheel Bearings and CV joints are a PIA if new to the process.
    I did my own wheel bearing . I did one part/ step different than that of using a slide pull or other methods. I removed knuckle … I removed the four retaining bolts for the wheel bearing....sprayed WD40 between bearing race and steering knuckle inner lip. Partially reinstalled 4 retaining bolts. Suspended knuckle of scrap blocks of (4x4) . Took another scrap of wood placed on top of retaining bolts and hit with 3-4 whacks with plastic dead blow hammer. Bearing came loose thereafter.
    I have only had partial success with slide pulls. because sometimes they are overkill
    #21 NortTexSalv04Prius, Oct 3, 2019
    Aegean likes this.
  2. jessiejosco
    jessiejosco Member
    62
    42
    The nuts are pretty soft. I do try to punch out the dent but, as was said, the hardened axle is way stronger than the nut. I don't use an impact wrench. I loosen it while the car is on the ground with a long breaker bar before I start. The nuts are cheap so I would not risk reusing one. Pretty sure that nut prevents the wheel bearing from ever coming apart. I always wonder about the rear bearings that are not held together with an axle.
    Mendel Leisk and Stimp like this.
  3. ChapmanF
    19,019
    Every manufacturer's manual I've ever seen has advised to use the brakes to lock the hub against rotation, then loosen the nut with a steady pull on a breaker bar (or, for mild-mannered me, often a breaker bar with a pipe over it). That's easiest if you have an accomplice to sit in the car and mash on the brake.
    With an impact wrench, you could probably do without the accomplice, because of enough inertia in the hub and drive axle that the impacts could surprise the nut loose. What's not to like?
    Well ...
    How do you brinell a bearing? Repeated sharp impact loads are one way. Like from an impact wrench.
    Now, in most cases, you're doing this because you're going to throw the old bearing away anyway. So no big deal. As long as you're not planning to use the impact gun to install the nut on your good new bearing. You'll use the torque wrench for that, and a nice steady pull.
    On the other hand, you probably weren't planning to also replace the CV joint, which is built out of machined polished rolling elements like a bearing, and is also getting all that nice impact transmitted straight into it by the stub shaft.
    Ironically, if you just had your accomplice in the car mashing the brakes, that might be holding the hub still enough to protect the CV joint from the impact wrench. But if you had the accomplice, you could just pull on a pipe and use no impact at all.
    Conversely, if you're using the impact wrench so you can skip having somebody hold the brakes, then the impact is traveling straight to the CV joint.
    #23 ChapmanF, Oct 3, 2019
  4. Mendel Leisk
    42,343
    There's a gizmo for restraining the hub, using a couple of pieces of flat bar:
  5. Patrick Wong
    18,210
    6,517
    Yes, since I am doing this work myself I frequently don't have someone to depress the brake pedal; hence use the impact wrench to loosen the nut. However, in his customary thorough and complete manner, Chap pointed out why this is not an optimal repair method.
    Mendel provided a potential workaround if the tool shown in his sketch perfectly fits the two lug studs without play.
  6. ChapmanF
    19,019
    That looks a whole lot like a thing I've had since high school that they sold me at the local friendly auto parts store and just called a "flywheel holder".
    Strangely, I've just been through fifteen pages of Google Images for "flywheel holder" and seen a plethora of different ways to build a flywheel holder (many of them for small magneto-y engines) but nothing like the one I've got.
    It's fairly versatile. The joint between the two bars can freely pivot, so it'll hold pretty much anything that has a couple of bolts or studs or pins any reasonable distance apart. If you don't tell it the thing's not a flywheel, it won't ask.
    Mendel Leisk and Patrick Wong like this.
  7. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    I have an impact wrench that could easily handle the axle nut but I will not use it after reading the caution in the manual and your logical explanation for the potential damage to the CV joint. For the same reason, I will not try to use an air chisel to remove the wheel hub from the knuckle.
    I ordered a 24” breaker bar and I hope it will work on the axle nut without drama.
  8. ChapmanF
    19,019
    If I ever have to change the hub, and it's stubborn, I possibly would consider the air hammer or chisel to persuade it out. That would be the bearing I'm going to throw away anyway, and the stub shaft to the CV joint should be removed from it by that stage of the proceedings.
    At 24", you'll have to pull at least 80 lbf on the end of the handle to loosen a 160 ft-lbf nut (more if it has been sitting there for a while, and no longer considers itself a 160 ft-lbf nut).
    But a nice length of pipe over that handle will make everything nice and civilized. (As long as you don't pull the car off the jackstands.)
  9. Mendel Leisk
    42,343
    I downloaded a video, a guy doing second gen bearing replacement, all hand tools. Unfortunately he doesn't have a logo in the video, and I can't find the YouTube link. I'm pretty sure he posted it on PriusChat, that's how I noticed it at one point. Anyway, He uses what looks to be a 24" breaker bar on the axle nut, and it looks to go pretty easy. It could be argued he pre-loosened it, but I don't think so. That leverage really helps.
    Good video btw, maybe someone else can find it. The guy has a central European accent of some sort, it looks to be done in a shop parking lot, out in the sun, and there's a fair bit of wind and traffic noise.
  10. ChapmanF
    19,019
    Trust me, whatever's easy with 2' is twice as easy with 4'. :)
    It also probably does depend somewhat on how long the nut has been there, and whether it still considers the factory torque spec to fairly depict its current disposition.
  11. jessiejosco
    jessiejosco Member
    62
    42
    The axle nut comes off pretty easily with a breaker bar. If you loosen the nut while the car is on the ground the parking pawl is all you need to hold the wheel. With a breaker bar you don't really need any strength. You can always put the breaker bar on the nut so it is horizontal and sit on it. 170 foot pounds is not that much. I think my old Saab specified 400 for its axle nuts.
    The only things I worry about when doing these is getting the bolts and nut off the ball joint if they are really rusted on, but that has not been a problem.
  12. Aegean
    464
    209
    Alexandria VA
    I spent 3 hours and replaced the right wheel hub. I will do the left tomorrow cause some things went wrong. I bought two used knuckles which include OEM Koyo wheel hubs and ball joints for $150 both. The idea was to replace the whole thing without dealing with the hustle of getting out the old steel wheel hub from the aluminum knuckle.
    The right used knuckle came with a ball joint that had the boot cut. When I received the part I took out the circular dust reflector that was in the way and with a breaker bar and some penetrating oil I was able to take out the nut of the leaking ball joint. It has also a reusable clip that goes off easily. Reversed the nut, hit it with a hammer and took the ball joint off without drama.
    Then I jacked up the car, added a stand for safety, took the wheel off with my electric impact gun.
    Using a Schley 65400 tool ($40, pin and 30 mm 12 point impact socket) I un-staked correctly the axle nut and using a 24” breaker bar the axle nut came off easily. I sticked a screwdriver on the top of the disc which kept resistance on the caliper bracket so the axle was not rotating.
    With a 10mm socket and an extension I removed the sensor from the knuckle.
    I removed, using a 17mm socket on my 24” breaker bar, the two bolts holding the caliper and hung it from the strut with a wire. The top bolt needed an extension.
    Then I took off the reusable clip from the tie rod and took the nut off with a 17mm socket. I reversed the nut, hit with a hammer the knuckle a few times and some more times the reversed nut and finally the tie rod separated from the knuckle.
    With a 17mm socket I removed from the bottom two nuts and one bolt that were holding the ball joint.
    Pushed the axle with my finger and surprisingly moved, took it off the knuckle and used a stand to not let it hang on it’s own.
    Finally, using a 19mm socket and a second 19mm tool I removed the two nuts and bolts holding the knuckle at the strut. I had space and used my electric impact gun but the breaker bar should work too. I took the whole knuckle off the car.
    Problem one, I tried to remove the ball joint from the knuckle that was on the car to re use it since the other one had a cut boot. The nut broke and I could not take it off. Local part store did not have a ball joint in stock. So I decided to put back the ball joint with the cut on the rubber boot.
    Installed everything back in the order that were removed, ball joint top nut 52 ft-lbs, strut bolts 113 ft-lbs, two nuts and a bolt for ball joint 66 ft-lbs, tie rod nut 36 ft-lbs, caliper bolts 81 ft-lbs, sensor bolt 71 inch-lbs, a brand new axle nut at 159 ft-lbs. and the wheel lugs 75-80 ft-lbs.
    Problem 2, when I took a test drive there was a lot of noise. I thought it was the disk shield touching the disk. Took the wheel off tried to bend it to give more clearance, installed wheel and second test drive. Same situation. Took the wheel off again and with a flashlight checked all areas between the disk and the shield. I use pliers and a flat screwdriver making sure it does not touch. Remember in order to remove the ball joint I manipulated the knuckle a lot. Put the wheel on and test drove. Luckily, the noise was not there any more.
    Tomorrow I will do the left knuckle but hopefully I will not mess up the disk shield and I will not touch the ball joint.
  13. Aegean
    464
    209
    Alexandria VA
    I highly recommended buying a used spindle/knuckle which is a direct bolt on without dealing with a stuck wheel hub. The driver’s side took me under an hour and works perfectly.
    The question for you is; do I need to do alignment as typically is done when you touch the suspension? I drove the car and keeps a straight line. What about camber, caster and any other terms? Does this mean even if the car does not pull to one side the tires will probably wear off unevenly now that I have changed both knuckles?
  14. Patrick Wong
    18,210
    6,517
    I suggest you consider replacing the ball joint with the broken rubber cover soon, as the grease will eventually leak out and cause the joint to fail.
    Yes, it would be good to have the wheels aligned once you are done working on the front suspension. The camber and front toe in are both adjustable.
  15. Aegean
    464
    209
    Alexandria VA
    Yes I keep thinking about this. I will try to take out the ball joint from the knuckle I removed already. It looks good.
    I hope I will be able to take off the upper nut from the ball joint that is already on the car without taking off anything else again. I had it tightened on Saturday at 52 ft-lbs. The Toyota engineers designed it in a way that the front wheel hub deflector shield is in the way and a socket or a 12 point box end wrench can not be used. I will try to use a 17mm open end wrench but 52 ft-lbs is a lot for that tool.
    Then doing an alignment should be the end of this little project.
  16. SanGregprius
    SanGregprius Junior Member
    42
    17
    san gregorio ca
    Any tips to get hub out if I don't have an impact gun?
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The hubs can be swapped without removing the knuckle. Videos are available on YouTube. Use the AutoZone Loan a tool program to borrow a slide hammer kit. You may get lucky and it pops right out, or you may wear yourself out. Roll of the dice...........I wasn't very lucky and wore that slide hammer out, lol.
  18. ChapmanF
    19,019
    What part of the procedure is resisting you?
  19. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    I watched someone on Tik-Tok use the weight of the vehicle and a floor jack and metal bars to do all kinds of front end work. You literally have a 1000 pound press with the weight of the car that can assist you if you know how to set it up right...
  20. SanGregprius
    42
    17
    san gregorio ca
    Thanks I've got the 4 bolts out, the drive shaft is out, just trying to get the hub out now. I've whacked it a few times, been using liquid wrench, and have a 24" breaker bar. I've got a piston jack and the prius jack so not very confident in trying to use car weight to move it.
    I also don't have a tool rental space near buy. Not much rust so I didn't think it would be a problem.
    I've no angle grinder to try and use a bolt to force it out. Just a hamer and some hand tools : )
    Thanks for help
