Need advice on parts for installation of double din unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by Lehboy, Nov 12, 2014.
  1. Lehboy
    Lehboy Junior Member
    A bit of a lurker here the past few months - finally was able to purchase a headunit, amp and basic speakers to upgrade my audio setup.
    Basically I was able to purchase this particular head unit -
    The Sony XAV-612BT.
    So from what I gather I need to get the
    Metra 8226B Dash Kit
    Do I also need the following parts?
    Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker
    Metra Axxess ASWC Universal Steering Wheel Control Interface
    Metra 70-8114
    Thanks Guys
  2. BillyBuerger
    BillyBuerger Junior Member
    26
    I
    I can't vouch for those specific parts, but the wire harness would be highly recommended. You can do it without it but it's not worth the hassle. The steering wheel control isn't required if you don't care about loosing the steering wheel controls. I don't use them myself so I might not do it myself if I was upgrading. But then again, it's not that much money. So probably better to do it all at once that to have to pull it all apart again later.
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Please clarify. Gen II or Gen III? The 2009 Prius can be either depending on your country of origin and you Bio does not specify. Metra 8226B Dash kit implies you have a GEN III and Model/Level III implies you have the JBL system from the factory, correct?
  4. Lehboy
    Sorry frodo, using the ZVW30 right hand drive from here in Australia. I believe it's the GenIII. As far as I know the model I have doesn't have the JBL system - it's part of the higher model sold here
  5. frodoz737
    4,297
    2,348
    33
