Need advice - Outlet caught fire
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cheung_francis, Nov 27, 2012.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Just for info. I was in my kitchen nothing plugged in anywhere. I was washing dishes by hand, all of a sudden smoke came rolling out of the gfci next to me, melted it inside no load what so ever on the circuit at the time. So it can happen just about any time.
    Andyprius # 1 and lensovet like this.
  2. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    For us here on on the forum there is perhaps too much room for guesswork. There is a lot of good information here, but we can't study the details of your situation. We can't look over the scene, rule things out, come up with a high reliability answer. You might want to bring in someone who is a licensed electrician in your area, let them run an expert eye over the situation.
    If the situation is ambiguous, or if you care to, you could run a dedicated 20 amp circuit, give the car its own outlet, its own breaker, not be concerned about what else is sharing its circuit.
    ftl likes this.
  3. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Why would the Bathroom GFCI be wired to Protect the Garage outlet ???
    However, since the bathroom WAS affected by using the garage outlet, it must be. Strange.
    Get an electrician.
  4. Post 16 and 20 & 23 are your best options. For charging use a dedicated outlet, only for charging the Prius. Put a new outlet in and check the voltage at the circuit breaker box coming in. This voltage and the outlet voltage should be identical. If there is a difference, there is a voltage drop (loss) and that should be investigated. Since you sound like a relatively new owner of the house, you should check all the outlets in the entire house. You never know what a previous owner might have done. Naturally replace the GFCI. If you can't handle this, hire a Electrician. Oh, if you can do so, bring the car in the garage and charge it. Eliminate the extension !
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    because them things are not cheap and no reason to put more than one on a single circuit. the GCFI protects EVERY outlet that is on that circuit
  6. I took mine out and put a regular outlet in my bathroom as the ground fault interupt was constantly interrupting my voltage supply to three bathrooms. That was 40 years ago! No problems since. At the time I had access to a Elec Lab and checked the GCFI, it worked perfect, blew right at 50ma. I assumed at the time since the house was new, the device was not wired up correctly.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Your last sentence is the most important! We cannot be his electrician over the internet.
    It is cheaper and nearly as safe to use one GFCI outlet to protect a whole series of 'normal' outlets that cost 1/10 as much. The problem for Prius owners is that the car charges for much longer than a 'normal' bathroom appliance and should be on a dedicated circuit near the car. (no extentsion cords)
    You need GFCI protection in wet locations (dirty water conducts electricity well) with plumbing. (plumbing may well provide an accedental ground) These areas allow electricity to go astray from the intended path. The new path may go through you! Bathrooms, kitchens and garages meet this description so should be GFCI protected.
  8. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Only if it's wired that way.
  9. PeterY
    PeterY New Member
    East Aurora, NY
    This has all been speculation and guessing. He's not even sure if garage and bathroom were same circuit, said "apparently". I agree with the comments that he should have it checked by an electrician.
  10. DLee
    DLee Junior Member
    81
    Did the OP say the bathroom outlet was a GCFI?
  11. lensovet
    2,615
    496
    Burlington, NJ
    OP hasn't said anything since his initial post, lol.
    WE0H likes this.
  12. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I had the same situation on my 1950s house. Bathroom plug tied into the garage. When the gfci would pop the sprinkler system would turn off. When electrician installed new panel and new circuits he said hair dryers pull more electricity than most anything -- heat wires and can cause fires on these old houses. The new circuit outside was made a 240 and my evse was sent in to upgrade to 240. Love my car because of it.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    But he checked PriusChat at 1:30 AM today.
    WE0H likes this.
  14. bisco
    52,062
    i would have a licensed electrician look at this, don't fool around with potential house fire.
    WE0H likes this.
  15. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It's common practice to run a branch circuit through a wall outlet. Since they didn't have GFI outlets 40yrs ago- that bathroom outlet was a standard outlet up to a few years ago when someone replaced it with a GFI outlet. When the GFI pops- the rest of the circuit downstream goes out now too....
  16. Was there really an OP?
  17. 3PriusMike
    3,100
    2,419
    Silicon Valley
    It is a fairly common practice to do this. It is required by the NEC to protect outlets that are near water (bathroom) and/or outside with a GFCI. But you can protect many outlets with a single GFCI. And since the most common way to trip a GFCI is from something like a hair dryer, they always put them indoors and in the bathroom, so you can find it and reset easier than if it is outside or in the garage.
    Mike
  18. cheung_francis
    cheung_francis Junior Member
    Thank you for everyone's responses. I have a licensed electrician scheduled this weekend to check things out. I will post again with what the electrician recommends.
    Yes, the outlet that caught fire in my bathroom was GFCI.
    lensovet likes this.
  19. lensovet
    2,615
    496
    Burlington, NJ
    good luck, and do keep us posted :)
    Andyprius # 1 likes this.
  20. cheung_francis
    Hi Everyone,
    Here is the update as promised. I had an electrician take a look.
    Basically the problem was due to aluminum wiring in my 40 yo home. The aluminum wiring that is connected to each 110v outlet and light switches tend to contract when heated and expand when cold. When contracted, there are "air pockets" between the aluminum wiring and the outlet that it is connected to. "Arcing" or sparking can occur and ultimately caused the area to be hot enough to melt the plastic and cause a fire. The clicking I heard from the outlet before the fire was the "arcing". The solution is to do a "pigtail" where copper wiring is attached to the aluminum house wiring just for the connection to each outlet.
    The electrician replaced my bathroom GFCI outlet, the casing around it, but had to install it about 8 inches higher than my previous location because my wiring was all charred due to the fire. I have since fixed the drywall and patched things up. The outlet in my garage was replaced with a normal 110v outlet, but he also "pigtailed" it to prevent this from occurring again. I have also upgraded my extension cord from a 14 gauge to a 12 gauge. 2 hours of time and about $200.
    My next project is to have the electrician "pigtail" all my outlets in the home. Until this is done, I have refrained from connecting high draw devices for long periods of time such as portable heaters, hair dryers, and xboxes. I make sure these devices are off when I am not home.
    I feel lucky to have been home at the time to catch and knock out the fire.
