Need advise on Transmission oil change and O2 sensor socket
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Arif Ahmed, Jan 2, 2018.
  1. Arif Ahmed
    Arif Ahmed New Member
    New Zealand
    Hi all
    I called my local Toyota Dealer here in Wellington, New Zealand for my Gen 2 Transmission oil. And they were asking for NZ$170. I don't feel like it is a reasonable price as it comes out to be 3 times the price of after market transmission oil. Perhaps anybody from New Zealand can inform me where I can get the original Toyota oil at a reasonable price? Also is this price justified? It comes to around US$120 for the 4 litre. Is that how much just the oil would cost in US?
    I also want to buy an O2 sensor socket. Can anybody let me know what size socket should it be?
    Thanks again.
    52,857
    $120. in the u/s would include installation. are you sure that is fluid only?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That's very expensive. Just use any other fluid you can get locally that has the WS specs. Its basically a Dextron 6 viscosity wise. Its a very tough trans it will not care.
  4. dolj
    dolj Senior Member
    8,646
    4,397
    So, to clarify, is this just for a 4 L container of ATF-WS from the parts counter, or was it for a transaxle oil change at the dealer?
    If it is just the parts price, it seems a little high.
    Also you may want to check your service history, as Toyota NZ does the transaxle oil change as part of the fixed price 90,000 km service.
    Just remember, you cannot compare prices in other jurisdictions, especially USA. NZ is just a little Island in the bottom of the Pacific and we continue to get price gouged under the guise of freight charges for (relatively) small consignments, given our population.
    Check TradeMe, there are a few car parts sellers there who sell genuine parts, and some with slightly better pricing.
    You could also check on the Penrite and Nulon websites to see if they have compatible ATF-WS. I haven't gone there as the information from Toyota on what ATF-WS actually is, makes it very difficult to judge whether a competitor's product is the equivalent. Plus Toyota already have done the change on both my Prii, so I don't need to go there for a while.
  5. Arif Ahmed
    New Zealand
    Yeah. I specifically asked only oil, don't want it changed. And the guy at King Toyota said $170.xx. My car has a mileage of half a million as it was driven as a taxi by the previous owner. I read on this forum and many suggested to get original ATF-WS from the dealer and not to buy after market oil. Any thoughts on that?
  6. Arif Ahmed
    New Zealand
    Yeah
  7. Arif Ahmed
    New Zealand
    My car has 549,000 kms on the clock. Do you think an after market oil will be a good idea? I read in the forums most people suggested to get original oil as after market does insulation damage or something to the motor??
  8. padroo
    padroo Senior Member
    2,763
    2,253
    I am no oil expert but I would run the Toyota oil. It is easy to change, remove the plug, drain the oil out and pump the new in. It's not like a regular automatic transmission, it's more like filling a gear box.
  9. dolj
    dolj Senior Member
    8,646
    4,397
    When was the transaxle oil last changed?
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yep it is just filling a gearbox. With that kind of high mileage why bother dropping that much money on
    4 quarts of atf.
    Nothing special about WS just a vey low viscosity D6 trans fluid with a big calcium pack for long life.
    It’s not even synthetic.
    Look around at your auto parts store for a WS compatible fluid. There should be plenty.
    Arif Ahmed likes this.
  11. dolj
    dolj Senior Member
    8,646
    4,397
    The Redline Oil D6 ATF Automatic Gear Oil that EdTheFox mentioned is available direct from Redline NZ for NZ$39.95 per US quart (946 ml) bottle. You will need 4 bottles.
    Redline NZ – D6 ATF Automatic Gear Oil
    I was charged NZ$149.92 back in Dec 2013 for 1 (fill) of Toyota ATF-WS. Then add GST (local consumer tax) of 15% and it comes out at $172.41. So may be correct.
    #11 dolj, Jan 3, 2018
  12. Arif Ahmed
    New Zealand
    To be honest, I have no idea.
  13. Arif Ahmed
    New Zealand
    I did find a good deal at SuperCheapAuto on a WS compatible Penrite oil. I think it was around NZ$60 for 4 L
  14. Arif Ahmed
    New Zealand
    Although the mileage is high, the Hybrid battery was just replaced. So I am expecting the car to live for a good amount of time.
  15. Arif Ahmed
    New Zealand
    Can anybody inform me what should be the diameter of the tube/pipe that I need to refill the fluid. I am planning to to fill it from the top rather than using a pump.
  16. uart
    uart Senior Member
    4,220
    1,212
    Australia
    SFO and Arif Ahmed like this.
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    That eBay is cool. Not sure how it’s only 14 from Scottsdale to NZ but.
    The flexible funnel has to have a very small nozzle. Make sure you get the fill hole open first and that fill hole bolt is really really on there I think they used thread lock on it. You will need a breaker bar and possibly assist pipe. It’s difficult diy as you have to get the car up very high to do this.
    Dump it all in a wide mouth receptacle. Take that old fluid out in the sun and stir it up good and see if you see any non ferrous bright metal particles in it. Good check for wear. I’m sure it will be jet black.
    Since the car is up in the wind now is the time to do the inverter coolant change. That’s really the most important fluid in the car imho. That’s very easy. Dump bolt right next to trans dump bolt under the car. Fill it back up with Toyota SLLC and bleed it. You should see instant mileage improvement as the inverter will run much cooler and be very happy. That fluid cools both the inverter and the trans. The inverter is the hardest working device in the car.
    I usually clean the under dash ac ecoil too I make the most of the car that high up in the air.
    I use Koolit from amazon just hook the can up and inject the cleaner.
    It’s a busy day. I use RedlineD6 trans fluid and Water Wetter in the inverter coolant. Have since the day I bought the car new 10 years and 120000 miles ago.
    Good luck down there.
    j12piprius and Arif Ahmed like this.
  18. Arif Ahmed
    New Zealand
    Thanks a lot for this link. That is a great buy. I actually called Toyota again and confirmed it is indeed NZ$175 (US$124) just for the ATF. To have it changed by them, they are asking NZ$230 (US$163).
  19. Arif Ahmed
    New Zealand
    Definitely thinking of doing the coolant change after your suggestion. Thanks for that. Coolant price from Toyota is NZ$47 (US$34) for a 4 L bottle. So I guess that is reasonable.
  20. bisco
    52,857
    great price on the labor, ask them if you can bring your own fluid.:)
