Need Bigger 12V battery...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by banshee08, Oct 7, 2009.
  1. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Ken,
    Is it safe to draw close to the 120 amp max constantly from the converter, or is there a duty cycle? I'm thinking of using the Prius as emergency power. I'd like to tap the traction battery directly, but that's probably prohibitively expensive.
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    It is constant 120A max, however I don't know how safe it is constant 120A consumption.
    I think it is a same kind of question "how safe is it to drive Prius 110mph for hours?".
    Anyway, if I were you, I'll try to limit up to 100A consumption on Gen3.
    Ken@Japan
  3. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    If you haven't seen before in my other posts, I have a fairly significant install and am running a JL HD900/5 which is kind of the same as running 2 amps. Either choice between the Alpine and JL you should be fine. They are so efficient with their power they are quite amazing. I am not completely done with my install as I am going to add another headunit into the center console to take care of audio duties as there just doesn't seem to be a reasonable way to get good sound going through a processor coming of the JBL factory amp. I have over $5k tied up in my system so far and am so disappointed in how it sounds. The installer had used an Alpine headunit at one point and bypassed everything just to make sure it sounded the way it should and holy cow, it was just absolutely amazing. Truly the audiophile sound I was and still am looking for. Only problem now is baby is on the way in less than a month, having surgery on my foot in Dec. so extra money won't be coming my way until I get back to work next spring and I just have to deal with it until then. Then from there the factory unit will play the voices through the stock dash speakers that come from the navi and phone stuff. Darn shame it has to come to that but too far over my head in this install to stop. Good luck with your install.
  4. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Just for an example. In my Altima Hybrid, I have two McIntosh MCC404 100watts x 4 amplifers and one Class D Arc Audio 500watt x 1 . Before I upgraded my battery to a Kenetic 1800 (second largest in the line up), I could see the headlight dim when I had the system playing semi loud in ready mode. I know class D is much more efficient but amps are amps and i don't think the 120amp will be able to handle 2 HD amps very well especially if you have really inefficient speakers like Dynaudio or Focals. I will do some testing in the coming weekends as my amps arrive.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    For those not good with numbers, 13.8V at 120A is indeed 1660 watts - not 1656. :cool: That also 2.22hp
  6. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Your calculator must be made in China. :)
    Ken@Japan
  7. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Got me thinking, where is my calculator made. Wow Taiwan!!!! When was the last time you got anything made in Taiwan.. hahaha
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    In what number system? This must be new math. ;)
    Tom
  9. rrolff
    1,610
    246
    So Cal
    No - it was made in Redmond, WA :cool:
    When calculating numbers, you cannot add accuracy to a number (unless you are looking for an inaccurate number).
    13.8 has (3) significant figures. 120 also has (3). The resulting number should also only have 3. So the accurate answer is 1660 - not 1656.
    Same for HP if the combination of numbers have (3), then the answer should have (3)....;)
  10. qbee42
    18,058
    3,079
    Northern Michigan
    Ah, so you are talking precision, not arithmetic. That's a relief. I though you might have a spider caught under the index of your slide rule.
    You can add as many significant figures as you wish, although they might not be useful. As you have pointed out, in engineering and the sciences we tend to explicitly list significant figures, even if they are zeros. In finance and accounting the rounding rules are completely different. For some reason the accounting people don't want you to create money. Go figure.
    In the case of a 12V power bus it is even worse, since you are talking about nominal voltages. If we want to get picky, we should probably refer to a range of voltages, just as we do with AC power: 110-120VAC. The 13.8 figure is common for conventional voltage regulators. I believe it might be a tad high for the Prius. It seems that the Prius likes to run at about 13.7 volts, but I haven't seen a formal specification.
    On to other nit picking: Sticklers Unite!
    Tom
  11. pgannon
    pgannon Junior Member
    Rancho Cordova, California
    a64pilot, go to Youtube.com and search "prius emergency generator" to see what people have done with their Prius's to power their homes. :)
