Need constant power fuse on driver side
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Imaginex20, Apr 14, 2017.
  1. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    I installed a dash cam in my car but failed to find a 12V constant fuse to tap into in the driver side fuse panel. Can someone help point me in the right direction?
    Dylan Doxey likes this.
    52,819
    maybe you'll have to sneak a wire through the bulkhead.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I usually just hook stuff up to the cigarette lighter circuit.
    52,819
    is that live with the car off?
  5. ChapmanF
    19,001
    By "constant", you mean you want the cam powered at all times, even when the car is off?
    What does it draw?
    The wiring diagram should show you several suitable circuits available under the instrument panel.
    -Chap
  6. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Yes, constant at all times. I have the hardwire kit that will stop drawing power below a certain voltage.
  7. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Update:
    I did some more searching and I found out that all the fuses in the middle column have constant power even when car is off, so I tapped into one of those fuses. Now my dash cam will record even when the car is off (motion detection)
    Bohemian Grove likes this.
  8. mrbigh
    3,686
    699
    Long Island, NY
    be careful with that constant current draw, your AUV 12 v battery will suffer the consequences.
    apt5020, Mendel Leisk and Dylan Doxey like this.
  9. Dylan Doxey
    1,389
    3,459
    92
    That's a fact.
    My bird's eye camera system would kill my 12v if I didn't drive the car for several days.
  10. Mendel Leisk
    42,317
    I'd second that: installing a device that continues to draw power when the car's off seems a fool's mission.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    As others have mentioned......our accessory 12v battery is 1/3 the size of a traditional 12v battery. Unless the cam has its own battery supply, I would be very cautious & would expect ur battery to last longer than 2 years.
    iPhone ?
  12. Mendel Leisk
    42,317
    If the camera would activate only for limited time, due to motion or sound, that'd at least be better.
  13. interested
    interested New Member
    GB
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The power outlet (cigarette lighter) isn't powered unless in Accessory or Ready. It's not powered in standby.
    Dylan Doxey and Mendel Leisk like this.
  15. Eodguy
    Eodguy Junior Member
    Seattle
    I ordered this power cord from amazon and taped into the power for the mirror. It comes on when I start the car and turns off when I stop. You can get constant power up there too if you want it.
  16. WesleyRiccipio
    WesleyRiccipio Junior Member
    103
    24
    It may appear that way. But if one has over 100Ah capacity and a couple 100W solar panels, it don't matter :)
