Need diagrams for replacing driver’s window switch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Envirogator, Mar 6, 2018.
  1. Envirogator
    Envirogator Junior Member
    Fl
    2018 Prius
    The rear passenger window goes down, but not up from the driver’s door switch. It works fine from the passenger door. Toyota wants to replace the entire switch, but since it was working for about 8 months (we bought it used) and sudently stoped working. I am thinking that it just might be a loose cable conection or a dirty contact. I am looking for any Toyota diagrams or home-made videos for taking the switch from the door, in order to use some electronics spray cleaner and checking the connections. But I do not want to break any plastic clips or parts in the process. Thanks a lot in advance.
  2. padroo
    padroo Senior Member
    2,763
    2,253
    There was a TSB I remember seeing about not using silicone sprays like Armorall around Toyota switches like your power window switches. It must insulate them and cause a bad connection by the way it reads.
    I know some people spray that stuff right on the switches instead of on a rag to wipe it around.
    Sorry I can't help you on switch removal.
  3. Envirogator
    Fl
    2018 Prius
    Thanks for the reply. I never spray directly, just on a microfiber cloth.
    padroo likes this.
  4. padroo
    2,763
    2,253
    Is this it?
    frodoz737 likes this.
  5. Envirogator
    Fl
    2018 Prius
    That’s it. Thank you!
    padroo likes this.
  6. padroo
    2,763
    2,253
    Good luck, let us know how it worked out.
