Need Help - 2010 Prius - P2196 + Blinking windows master Switch
Discussion in 'Gen 3 Prius Technical Discussion' started by saak, Jul 12, 2016.
  1. saak
    saak Junior Member
    42
    Alberta, Canada
    NEED HELP.
    Just bought this car, while driving for the first time, engine light came on, Mileage is 160,000 Km. Scanned the car with tech stream and found these codes.
    P2196
    B1206
    B2321
    B2313
    Its an Air fuel ratio sensor code, could it be something else ? Where this sensor located ? is it under the air box or in the back, can I replace it my self ?
    Cant unlock or roll down passenger door/window, Same with one of the rear windows.
    Passenger door unlock fine when I press PARK. Can roll down passenger and rear window from the switch on those doors, just cant seem to work from master window switch, plus all three windows lights were blinking except driver switch.
    Thanks.
  2. JC91006
    16,936
    8,647
    Can you bring it back to where you bought it?
  3. saak
    saak Junior Member
    42
    Alberta, Canada
    Private Seller so no I cant take it back.
  4. JC91006
    16,936
    8,647
    try cleaning the MAF sensor and throttle body first. Afterwards, disconnect the 12v battery for a minute to reset the car.
    The air/fuel sensor is towards the front of the exhaust manifold. It looks like an oxygen sensor and will require a special tool to remove it.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Hope you paid a dirt cheap low price for it from the canuk
  6. saak
    saak Junior Member
    42
    Alberta, Canada
    Thanks. Is exhaust manifold under the air box or toward back of the engine ? Any advice on other codes and blinking master switch ?
  7. JC91006
    16,936
    8,647
    with the gen2 cars, it was towards the back of the engine. I don't remember seeing it any different in gen3
  8. saak
    saak Junior Member
    42
    Alberta, Canada
    Thanks for the advice.
    Cleaned the throtlebody and MAF. But after doing that, now I am getting Knock Sensor P0328 code, plus the P2196.
    I could not find the Knock Sensor, in pictures they show its on the front of the engine, but I could not locate. I wanted to check if somehow connector got loose or something. because there was no knock sensor code before. car running of but engine light comes on right away with same codes after deleting the code.
  9. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Check all of the fuses for the doors/windows. Could just be a blown fuse.
  10. saak
    saak Junior Member
    42
    Alberta, Canada
    I fixed the windows by relearn procedure of windows and all the windows are working fine. My real issue at this time is I have two code P2196 and P0328. I cleaned the MAF and TB in order to try to fix P2196, but after cleaning now I have Knock Sensor P0328, and its keep coming back after deleting the codes. I removed the air box but later find out knock sensor is behind intake manifold which is a lot of work to get access to the knock sensor. I did use sprayed throtle body cleaner a little bit in the TB.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    If there is TB cleaner residue left it will flash and could cause the knock and throw the code. Might want to run some miles off as this might be the cause.
