Need help determining cycling solenoid
Discussion in 'Generation 1 Prius Discussion' started by sandy11246, Jun 13, 2018.
  1. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Seems to be.a relay or stepper motor. Only cycles when ICE operating or in ready. Will not appear if I just turn to key on. No CE or Triangle. Vehicle runs fine. Thought it might a pulse width signal to fuel pump. Will try to locate area tomorrow and see if I can ID the part or unit. Any ideas welcomed. Vehicle has been runing great. Thanks to all! Peace.
    Andyprius1 likes this.
  2. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Checked all systems for codes and strange data indications. No codes and values seems fine. Sound seems to be coming interior from under dash or near firewall, but I'm not positive of location. I'm not even sure I have a problem but the sound something I haven't noticed before. If anyone has any ideas, please help. Right now I'm lost. I've manually cycled Evap solenoids and fuel tank with Techstream. Can't duplicate sound. Help.
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Turn up the radio and don't worry about it.
    Raytheeagle likes this.
  4. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Brian - What do you think it is. I would fell better if I knew what was going on.
  5. ChapmanF
    18,501
    There's a video attached to this thread with the sound of a noisy HVAC servo, in case it might be that.
    The video is actually attached to the thread (not hosted on a media site) ... can be downloaded, unzipped, and played.
    -Chap
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I used to know an idiot who really thought that way. I guess your commenting tongue in cheek?
    So it shouldn’t actuate until a HVAC change was made, or ignition ready?
    #6 Andyprius1, Jun 13, 2018
  7. ChapmanF
    18,501
    The HVAC dampers are positioned by servos—that is, actuators with built-in position sensor feedback. The ECU knows where it wants the position to be, so if the sensed position is different, it drives the servo toward the desired position.
    When the position sensor gets old and electrically noisy, it's as if the ECU is seeing the damper position constantly jumping around. So the ECU keeps constantly driving the actuator trying to get the position back where it should be. So no, it doesn't depend on you making any HVAC change.
    -Chap
  8. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Thanks Chap, I’ll get on it tomorrow. Don’t like things not working correctly. You guys are GREAT! If I need more assistance I’ll yell. Thanks again. It’s been running great and don’t want to lose it.
  9. Andyprius1
    2,327
    859
    Cool CA
    You may actually find some play in the linkage. Fortunately I have bad hearing, so everything works perfect, I don’t even have to turn my radio up, to drown out the knocking engine.
  10. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Thanks Chap for all your help as I work through our Gen1. Serviced AC door motor, now no noise. Linkage operates as it should. Vehicle is a gem, good in-town mileage and appears to get around 45+ Hwy. No real issues once I worked through the initial problems. First oil change coming up so 3000 plus since purchase. Only problem I had with motor was R&R as I'm 6'2" and 215# so getting under dash on left was a chore. No worries, got her done. Many thanks again. Maybe someday I will be able to help other with what I'm learning.
  11. ChapmanF
    18,501
  12. Andyprius1
    2,327
    859
    Cool CA
    TY You already have.
  13. ChapmanF
    18,501
    I've just added this same note on my original thread:
    For future reference, the Gen 3 Prius replaced these actuators having potentiometer-style feedback with a new design using Hall-effect sensors for the feedback. So this should be a very uncommon issue in Gen 3 or later. Gen 1s and 2s are likely to experience it as they age, and as you can see, it's very easy to fix.
    The one exception might be if the air-inlet damper is the one that gets noisy. The other two servos (air mix for temperature, and outlet select) are on the easy-to-reach side of the heater case. The air inlet one is much harder to reach on the other side of the case, sandwiched between it and the blower. The dash might really have to come off to reach that one. I never had to do it (had my Gen 1 up to 230,something thousand), but it is built the same as the other two, so somebody keeping a Gen 1 or 2 super long might eventually have to deal with it.
    -Chap
    SFO and Andyprius1 like this.
