Need help finding brake wire on drivers rear for hitch wiring
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Rrrolfff, Mar 18, 2019.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    Installing the wiring for my hitch (never knew uhaul will rent you 5x8 trailers for a prius)... I'm looking for the aft brake wire to splice into... turn signals are easy (green/yelliw)...
    Thanks!
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Just buy a kit where you don’t have to splice
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,495
    Taylors, SC
    Asian vehicles require a converter to use trailers with combination stop and turn signal lights used on US made cars and trailers. You can buy and install a converter. I don't know, if UHaul dealers would rent the converter, but I know that they sell and install them.
  4. MikeNinMass
    MikeNinMass Junior Member
    26
    Cambridge, MA
    Are 5x8's from U-haul a 4-wire flat cable? Four wire flats use the turn signals for brake lights. The other wire (besides ground) is for the standard tail light.
  5. Georgina Rudkus
    3,511
    2,495
    Taylors, SC
    The Prius has separate brake and turn signals. You need a 3-2 converter, because the U-Haul trailer has integrated turn and stop (brake) lights.
    Four wire cable on the trailer used brown for clearance/running lights, green for right turn, yellow for left turn and white for ground.
  6. MikeNinMass
    26
    Cambridge, MA
    oops! I was thinking about how I check if the trailer lights are working when I'm by myself - I don't need to press the brake pedal to check the bulbs, I just check that both hazard lights on the trailer blink. That's backwards from the question. Yes, I have a converter box to feed brakes into the turn signal circuit.
    sorry for the unhelpful info
    #6 MikeNinMass, Mar 28, 2019
  7. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
