Need help finding right product to get rid of odor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by darkgiant, Jun 28, 2017.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I am having issues with my 2011 Prius and bad Odor when using the AC, I tried a new Air Filter but the problem seems to be more than that. I am having an unusually hard time of finding the Toyota AC Refresher (here is a @NutzAboutBolts video as reference:
    ). I've tried various dealerships who are asking for nearly $50, and only see a couple of listings on eBay, both for $35 + $15 shipping (basically amounts to $50).
    My question is, I see in previous threads in the past where people found the Toyota AC Refresher kit for dirt cheap (I see people even finding them for $30), and I was wondering, does anyone have any idea where I can find it for roughly $25<? Or better yet, are there better alternative products that would be safe to use for the Prius? I am seeing I can spray Lysol into the vent above the hood, but I am not sure if I would still have to drain and clean the evaporator, as is a part of the Toyota kit? Any hep is appreciated!
  2. Former Member 68813
    3,524
    983
    US
    I bought it for about $20 on ebay (IIRC, maybe it was closer to $30?), but it was a few years ago. after seeing how it works, i used a cheaper method on another car that worked almost as well. I put 100% isopropyl alcohol in a spray bottle and sprayed as much as I could in the cabin filter opening (sans filter of course) letting it drain via the drain tube. later, i started AC on high (fresh air) and sprayed it into air intake under the windshield. be careful, it's combustible. you could also find the active ingredients of the toyota's spray, and purchase that separately, but i didn't do it.
  3. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Try Kool-It. It's another AC evaporator cleaner that works the same way as the Toyota cleaner. It doesn't include the can that sprays the air intake vent, but that might not be needed to remove the odor. In old posts here, some people here have reported that they skipped that air intake spray because it is scented, and they didn't want to breathe that. Something like Lysol might be equivalent to that.
    I bought some Kool-It on amazon.com because my car had a terrible stink when I bought it used a year and a half ago. I haven't ended up using it yet, because the stink cleaned up from elsewhere in the car, and there's no odor with the AC. I'll use it at some point though.
  4. Former Member 68813
    3,524
    983
    US
    good point about the used cars. the only 2 cars i had to service for AC smell were acquired used. the cars i have since new don't have problems, but i make sure to only use fresh air (no recirculate) and turn off AC half of mile before destination.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Koolit works great. Don't spray anything else in the vents it does nothing whatsoever except make you smell stink.
    Dealers get $125 here for e coil service here. Up on lift they attach the spray can of microbial cleaner with the rubber hose to the drip hose, the spray can contents is injected back up the hose as foam and then turns to liquid and drips back out the hose, in addition to cleaning the drip tube it also cleans the ecoil where the smell resides. The hard expensive part is getting the car high enough to get to the drip tube.
    If the car is used everyday the ecoil pretty much stays wet and mold does not set up but if you use the car a lot and the let it sit for days that's when it dries up and gets moldy.
    The dealer basicly uses koolit with another can of the most god awful jean natai old lady perfume stench u have ever smelled. Skip that can if dealer serviced.
    Koolit amazon.com $15.
  6. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  7. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Thats just perfume. Does nothing to clean the mold that is deep in the ecoil. You have to clean the coils just like you have to clean the coils on your home ac unit. You can spray perfume all day in the ac vents first time you turn on the ac it will just get blown out.
  8. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    My 2013 Pius plugin had a similar problem.
    My solution was to have my Mother-in-law exit the passenger seat and close the door :)
    Raytheeagle likes this.
  9. TRUC NGUYEN
    2014 Prius Plug-in
    Sold lot more than Kool-it for the pass 3 years cause it works and easier to use
  10. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    666
    265
    Dodge Co. Wisconsin
    2017 Prius v wagon
    With other cars I owned, (1 was always outside) we had a neighbor who's cat would piss in the hood and wipers and it stunk like hell. I took a pail of bleach water and dumped it on the wipers and on the hood, making sure plenty went down the vents. It worked well, but it was better when the cat "disappeared".
  11. darkgiant
    darkgiant Member
    287
    42
    Seattle
    So sorry for the late reply here... but it seems like Kool-It is the way to go?
  12. edthefox5
    10,096
    4,832
    Clearwater, Florida
    It's the way the dealer does it. It's benign it works and it smells great.
    Only hard part is getting the car high enough to get under it to the drip tube. First time do 2 cans douche it good.
    I usually clean the condenser too. Go to lowes buy 2 cans of Coil Cleaner in the ac filter aisle. Take the top plastic cover off the top of the rad.
    Hose the condenser down good with 2 cans of that cleaner. If really bug riddled let it sit then hose it off.
    This is nothing new here. It's basic maintenance the same thing you should do to your home unit.
    You will be rewarded with ice cold air.
    Owned my Prius 10 yeas ac is ice cold. House too.
    #12 edthefox5, Aug 4, 2017
