Need help guys
Discussion in 'Prius c Audio and Electronics' started by RobertJones324, Apr 25, 2015.
  1. RobertJones324
    RobertJones324 New Member
    Sturgis, Kentucky
    I have a 2015 prius c 4 and im needing to know what the color of the speaker wires are so I can hook my amps high level input up to it? Also where can I hook my remote wire to my up to
    52,762
    welcome! what's an 'up to'?o_O
  3. Motov8r
    Motov8r Member
    102
    This link has the right colors for the speakers. (Even though is says 2007 prius) There is no amp power on wire but you can use the power lead to the radio that will keep the amp on whenever the radio is getting power.
    2007 Toyota Prius Car Radio Wiring Guide
    iPhone ?
  4. RobertJones324
    Sturgis, Kentucky
    Thanks for the input. On the speaker wires I saw a video on you tube that a guy got to his speaker wire through the fuse panel on the floor and taped into them there instead of having to take the radio out is this true fir the prius c also is there a wire there that I can hook my remote wire to
  5. Motov8r
    Motov8r Member
    102
    You could probably tap the fuse panel itself for the radio fuse and use that as the amp remote.
    iPhone ?
  6. Motov8r
    Motov8r Member
    102
    By the way the head unit is super easy to pull and it's easy to route the wiring to the passenger side. Also lots of room behind the head unit for your line out to RCA converter.
    iPhone ?
  7. RobertJones324
    Sturgis, Kentucky
    If you have time to tell me how do you pull the head unit out
  8. RobertJones324
    Sturgis, Kentucky
    I ment to say into...lol
  9. bisco
    52,762
    thanks!:p
  10. Motov8r
    Motov8r Member
    102
    You grab the frame around the stereo and just pull it toward you. A small flathead screwdriver can be helpful to get it started. After you remove that piece you can see 4 screws that hold the stereo in.
    iPhone ?
  11. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Its pretty easy to remove the radio. Routing the wires is pretty easy on the C too since its pretty roomy in that area.
  12. RobertJones324
    Sturgis, Kentucky
    Where is the 12v battery located at in the car and how do you get to it? Thanks so much
  13. kingnba6
    1,018
    242
    NY
    The 12v battery is in the cabin. It is directly below the rear right passenger seat. You can access it by removing 2 or 3 clips and the cover pops right off.
  14. RobertJones324
    Sturgis, Kentucky
    Do you havd good access to it im going be hooking my power wire for my amp up to it
  15. kingnba6
    1,018
    242
    NY
    Once you remove the plastic panel, you will get direct access to the positive and negative terminals. So, yes you have good access.
  16. RobertJones324
    Sturgis, Kentucky
    Awesome im going to hook it up tomorrow
  17. RobertJones324
    Sturgis, Kentucky
    If I have to un hook the battery that won't mess anything up on the car will it?
  18. kingnba6
    1,018
    242
    NY
    Nothing bad will happen. The time and radio presets might be lost but other than that nothing else should happen.
