need help hv battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by no trust, Jul 13, 2011.
  1. no trust
    no trust Junior Member
    46
    Powhatan, VA
    To patrick wong, didnt catch your post in time. Put all back together drove another 100 miles 5 starts and stops all diferent coditions and bam the christmas tree lights i wanted to puke! I totaly understand your theory but working with the 220 or so v I fear. would there be a way to load test each cell with say an 8v or so lamp for a set time ,watch the meter and compare voltage drop without depleating the cell?
  2. Patrick Wong
    18,210
    6,526
    You could try that.
    One or two automobile headlights could be a good load. A 55W 12V bulb will probably draw ~3A at 8V. Put two in parallel to double the stress on the battery module.
  3. no trust
    46
    Powhatan, VA
    What is the modules full capacity? Would it be in amp hours and what is the formula for amp hours? Forgive me ,22 years as a construction electrician does not make me a wizard i feel like i should be on a gieco commercial! But to trust the dealership that cant install a 12v battery is impossible.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    6.5 amp hours.
    Let me relate an experience that I had with my stepfather. He has a 03 Civic Hybrid, which is a 20 module HV battery. He got the IMA warning light. I had him disconnect the 12V battery to reset the codes. That automatically triggers a negative recal when the car is restarted, meaning the entire battery pack is force recharged. Next, I suggested that he keep a very light touch on the throttle, to minimize the amount of current pulled from the battery. Other than one time where he had the cruise control on and it hammered the throttle when going over a hill, he did not have the IMA light come back on for 750 miles of driving. I let the battery sit for a week, and it was immediately clear which module ("stick") was bad. So it is possible that, at higher SOC, a bad module will not show up, but either time or deep discharge will reveal it.
    Before you hook up the light bulbs, reset the codes, put it in neutral, turn on the A/C to high, and let it go until you either get the triangle again, or the warning to put the car into Park to charge the battery. Then pull the cover off and check your voltages.
  5. no trust
    46
    Powhatan, VA
    I will try that, one more question ,where is module 2 , counting from ecu end or from duct end ?
  6. Patrick Wong
    18,210
    6,526
    Since your car logged DTC P3012, this means that the problem is within battery block 2. Battery block 2 is composed of modules 3 and 4.
    There are fourteen battery blocks, and therefore 28 battery modules.
    I don't recall which side the battery block 2 can be found on. However there is an easy way to identify it. When you open the battery case, you will note the orange traction interlock switch that you will have already removed as a safety precaution. That switch is wired so that, when open, it breaks the connection between battery blocks 9 and 10.
    Hence, once you have identified block 9, just move towards the end of the battery, away from where the switch is wired into the modules. Either module 3 or 4 is likely to be bad.
    If you want to do a complete job when replacing modules, I would suggest replacing six modules: 1-6. This is because whichever module has failed has overheated and has likely shortened the life of the surrounding modules. Hence if you replace all six there is a good chance that your repair job will hold for more than a few minutes.
    Good luck.
  7. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Count from the ECU side.
  8. no trust
    46
    Powhatan, VA
    ok, I let the car go to low soc, two bars. No more than 3/100ths dif between any modules,voltages 7.54 to 7.57 block 2 read 7.55 each. But yesterday brake light ,triangle,!,abs,and vsc came on when I tried using a neighbors AutoTap OBDII scanner with a laptop. Was unable to retrieve any code,reset with 12v disc. but brake,abs ,vsc remain on! Im thinking without the proper diog. tools im getting no where, and it will be hard to convince me that the loose + cable was not the cause. Im thinking one of the ecus.
  9. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    ohhh no... we have seen stories of generic scan tools undoing zero point calibrations in the braking system. If the lights do not go off with multiple restarts, see Patrick's post about resetting the light:
    http://priuschat.com/forums/gen-ii-...162-diy-disaster-need-help-3.html#post1150539
    If that still does not clear it, someone with a Techstream or other bi-directional scan tool may need to look at it.
    What if you measure voltages at the connection to ECU, i.e. 15.08V, 15.14V, etc. That would tell you if there is any issue with the wiring leading to the ECU. You can trace the sense wires to the connector to know which block you are probing. If that still looks good, then proceed with discharging the modules, down to 7.2V each.
  10. no trust
    46
    Powhatan, VA
    all the sense wires measure correctly. Did the jumper trick ,if i watch the ! flash only i get blink codes 48,66,95 . What do they mean?
  11. no trust
    46
    Powhatan, VA
    I checked blink codes again after reading another thread. ABS 42 VSC 45. I saw a thread that 48 was stroke sensor zero point looks like the autotap wiped it out! What are the other codes ? And by the way thanks to u all for sticking with me !
  12. no trust
    46
    Powhatan, VA
    ok to follow this posting refer to the post (blink codes) yea i know i should not have started another post . Sorry
