Need help identifying connector
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Joele3, Feb 21, 2025.
  1. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    Hello all,
    Looking for some help identifying a connector and or some wiring help. I ripped the wiring out of sensor while pulling the transaxle. Didnt catch it in time and wires pulled out of connector. I was able to source a new connector from a wrecking yard but its from a 2010 regular Prius and colors of the wiring is different. I have 2014 Prius V. I cant locate any in the wrecking yards around here. The connector hooks directly into one of the main harnesses on the driver side. It plugs directly right above the subframe. Here are some photos. I was thinking of peeling back some of the tape wire covers on the other side of the connector.
  2. Joele3
    137
    205
    Bay Area
    I was able to get the info from shop foreman works at Fremont Toyota. Cool dude name is T. If you live around the Bay Area. They have the best prices just order online for store pick up. Connector is for the oxygen sensor behind the catalytic converter.
