Need help identifying part
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chayashida, Jul 6, 2014.
  1. chayashida
    chayashida Junior Member
    Flickr: cshayashida's Photostream
    I need help identifying a sensor (or something) inside the driver's side front wheel well. It's hanging down in the center of the picture.
    It hangs off the electrical harness that connects to the A/C coolant system (I think). I don't know if it's safe to ziptie to the harness, so that it doesn't swing and contact the wheel while I'm driving.
    I ran over a truck tire tread on Friday on the way home from work, and it tore up the front grill and all the aerodynamic parts underneath the car, as well as the driver's side front wheel well liner. I suspect that's where this sensor was located.
    Any help or pointers would be appreciated.
    Thanks in advance,
    Chris
  2. chayashida
    Well, after I figured out that I could disconnect the sensor, I was able to read the part number: 89747-48020 068900-3840
    After Googling it, I saw it listed as a Lexus buzzer. When the buzzer is removed, the car doesn't beep when you lock or unlock the car. Horn still works.
    Anyway, hope this helps someone else that might get here via Google.
