Need Help Identifying These Front Lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by samochod, Oct 6, 2020.
  1. samochod
    samochod Junior Member
    Georgia, USA
    I've attached a pic and circled the 5 lights in yellow. Can someone please inform me what these lights are called? When should they be turning on? Is it normal for them not to be lighting up? I've tried different ways to get them to light and can't figure it out. I have a 2013 Prius 3.
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Those are called eye candy, that’s what they only serve as.
    samochod likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Aren't they daytime running lights?
  4. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    :ROFLMAO:
  5. Tideland Prius
    16,621
    There are no lights there. They are decorative.
  6. samochod
    Georgia, USA
    LOL - Okay, makes sense. As embarrassed as I feel right now, thank you for letting me know because I truly wasted a lot of time trying to figure it out.
    Last week I took my car (only 45k miles, regularly maintained) to the dealership for an oil change and software update. They took this as an opportunity to find over a thousand dollars worth of extra work, including bulb replacements. On the spot, I declined it all. But I've been going over their list. It says "Bulb (Frt Cornering Light) - Replace: 1 LEFT FRONT INOP." However, on my car that light works. The only lights that weren't lighting up are the five ones I circled.
  7. Tideland Prius
    16,621
    There are two parking lights on the Gen 3 - the forward facing one above your circled area and another one where the amber reflector is.
  8. fuzzy1
    10,603
    One or two prior owners went to great lengths and greater amounts of time to put actual functioning LEDs in such decorative slots, though I'm thinking that it was on a bit different headlight assembly.
    Tideland Prius and samochod like this.
  9. samochod
    Georgia, USA
    I narrowly avoided that fate by failing to find the part number!
