Need help identifying these headlight connectors
Discussion in 'Gen 2 Prius Technical Discussion' started by Max Finch, Oct 2, 2017.
  1. Max Finch
    Max Finch Active Member
    135
    131
    Medford Oregon
    Hey all!
    I went the “cheaper” route and purchase Halogen headlights for my HID Prius to do the Morimoto projector swap. To complete the build I’d like to get a hold of connectors to make the swap easier. I don’t want to splice into my wiring harness at all, want to be able to have a clean installation with the ability to go back to my OEM HID’s in the case that I sell it or it’s totaled (hopefully that never happens).
    Can anybody here identify what type of connectors these are?
    1) [​IMG]
    2) [​IMG]
    3) [​IMG]
    4) [​IMG]
    Any help is appreciated!
  2. Max Finch
    135
    131
    Medford Oregon
    Okay found out #1 is the Turn Signal Lamp Socket. Don’t need that part (took these pics on a wrecker). But if someone needs the part for future reference it’s part # 90075-60028
  3. greasemonkey007
    greasemonkey007 Active Member
    286
    105
    South Central Arkansas
    Seems like I remember seeing some pigtail adapters on ebay one time for about $7 when I was thinking about doing a conversion. I changed my mind when I found a good deal on some new bulbs.
  4. Max Finch
    135
    131
    Medford Oregon
    I ended up grabbing connectors off one eBay unit and one junkyard car for the high beams. Then I purchased the ballast connector from Toyota (it’s integrated in the twist headlight cap) which I’ll hack and somehow fit onto the halogen cover and seal.
    #4 is what I believe is a H7 pigtail and once I confirm that I’ll create a H7 to 9006 cable that’ll go from the factory wiring harness to the aftermarket Morimoto ballast.
    All said and done I think I’ll have these in by next week!
    SFO likes this.
