Need Help Identifying What Happened
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tduff311, Dec 13, 2017.
  1. tduff311
    tduff311 Junior Member
    76
    Medina
    Do you connect this to the trunk terminal or the engine terminal? Shop manager told me today you would want to use charger in trunk terminal, but that seems like a lot of work to be used as you mentioned
    iPhone ?
  2. tduff311
    76
    Medina
    How do you turn SKS off?
    iPhone ?
  3. Prodigyplace
    12,709
    11,847
    Central Virginia
    Have you changed the battery in the key fob?
    You say "the fob" I hope you have at least two. If not, buy a virgin fob and program it now while you can. If you lose your only fob, the repair can get complex & expensive.
    tduff311 likes this.
  4. tduff311
    76
    Medina
    Yes I did and it didn’t fix the problem. Still nonfunctional other than as a traditional remote and ignition key. It’s my only one, can’t find the other.
    Can you link me to a good post on how to program a virgin fob? I presume any of those on amazon work in this capacity?
    iPhone ?
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I wired a pig-tail (provided for that very purpose - it came with the charger) into the fuse-box in front, and plug in every time the car is in the garage. Here's a picture:
    - hope this helps -Wil
    tduff311 and VFerdman like this.
  6. Prodigyplace
    12,709
    11,847
    Central Virginia
    From your manual:
  7. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    Battery in the fob may be dead. Have you tried replacing it?
  8. Prodigyplace
    12,709
    11,847
    Central Virginia
    I believe you need at least one working fob to program another.
    If you do not have a working fob, I believe the dealer needs to "reseed" the immobilizer ECU in the car and then program one or more new fobs.
  9. Prodigyplace
    12,709
    11,847
    Central Virginia
    Yes. See post 64
  10. VFerdman
    1,200
    1,218
    It shouldn't matter where you connect the charger. A little pig tail connector usually comes with a charger and that can be installed either under the hood or in the trunk. Whatever is more convenient for you is what you go with. The pigtail is about a foot long or so, so it can be routed out to a place easily accessible in the trunk, like right in the storage compartment.
  11. tduff311
    76
    Medina
    Since the shop is replacing my battery and providing me a new one tomorrow, installed, from Napa auto parts, is there any benefit to using a charger throughout these cold winter months of northeastern Ohio? My drives are actually long unlike the other members here… I drive 1 to 1.5 hours each way to work every day.
    iPhone ?
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    My personal opinion? Install the battery and forget about it. Just like the million other cars in Ohio. It's a new battery, it shouldn't need any additional help to work correctly.
  13. bisco
    52,744
    agreed, and you drive plenty to keep it charged. if you are going to leave sit it for a long time, that is a different story.
  14. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Luckily it’s a lot less than that. Prius 12V battery can only take in 1…2Amp if its temperature is below -18c or 0F. And even less when it’s colder. So theoretically if it was draining that fast you would need to drive (or keep it in ready) for something like 4 hours a day (actually lot less as battery would heat up during that).
    You can clearly see the problem with charge acceptance if you try to charge cold lead acid battery with the modern “smart charger”. Many of those will just charge with constant current until the voltage reaches 14.4V and then stop. Unfortunately cold battery can’t take that much current in and then only after maybe 10 seconds of charging voltage reaches 14.4V but battery is still mostly empty. Thy do then cycle on after voltage drops enough but that just makes it very slow. It would be a lot better if charger would just keep the voltage regulated at 14.4V. Higher voltages would be even better at start of charging but only if you disconnect the battery.
  15. eman08
    eman08 Active Member
    360
    192
    US
    For tires I like to watch the techs do their job just by looking through the window so that I see them. Discount tires has those windows instead of behind closed doors. Other than that i do everything myself with the exception of front end alignment and tire mount. Trying to DIY tires is a pain in the nice person if you don't have a tire machine.
