Need help.....P0A7A...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Noahlr, Sep 3, 2018.
  1. Noahlr
    Noahlr New Member
    Iowa
    2008 with 113000 miles
    DTC P0A7A...all dash warning lights are on
    lost all acceleration while driving
    it will start for a few seconds then stall
    replaced with good parts
    Inverter
    HV ECU
    12v battery
    inverter coolant pump is functioning as it should...
    Any ideas before i take it to the dealer?
    i like to do my own repairs and maintenance whenever possible...
    we have had nothing but bad experiences at our local dealer.
    please if you have any ideas or suggestions i would greatly appreciate it...
    thanks Noah
  2. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    It means your Electronic Control Module (ECM) Is sensing a short from the Inverter.
    (Thanks for stating the obvious right?)
    Since you had someone replace the inverter, there is a good chance the problem is a Loose connection right?
    So disconnect your battery take out the orange plug and Check them all.
    I just swapped mine and posted a time lapse so you can see that and use it and a manual to check all your connections. When you’ve check this you keep your eyes out for anything that looks shorted and check fuses related to the inverter.
    There is a good chance it’s a loose connection and since the ECM wasn’t getting the information it needed its shutting things down.
    iPhone ?
    Noahlr likes this.
  3. Noahlr
    Noahlr New Member
    Iowa
    Thanks for the reply...
    I checked all wiring connections and fuses hoping that's what the issue was before I changed out the inverter and then the hv ecu. Any chance the inverter pump could be causing this even though its currently working? What fuses are tied to the inverter?
  4. Paul Schenck
    524
    307
    Fresno, California
    Toyota Prius (XW20; 2008 - 2009) - fuse box diagram - Auto Genius
    iPhone ?
    Noahlr likes this.
  5. Noahlr
    Noahlr New Member
    Iowa
  6. Patrick Wong
    18,210
    6,514
    I think you should get the repair manual info at techinfo.Toyota.com and follow the trouble shooting for DTC P0A7A. You have already replaced the two likely failed components so you now need to look for a failed wiring connection.
    Paul Schenck, Noahlr and strawbrad like this.
  7. bisco
    52,396
    why did you start a new thread?
  8. Noahlr
    Noahlr New Member
    Iowa
    I'm new to the site and posted in the main form....I didn't see the specific categories. Figured more people who were mechanically inclined would be in this category.
  9. Ricardo Oliveira
    Ricardo Oliveira Junior Member
    san jose, california
    I have the same problem you reported. Replace the inverter and nothing. What was the solution to your problem?
