Need Help QUICK! MPG dropped BAD and high RPM!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by F8L, Apr 9, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Me too. I just couldn't believe something like a bad tire could cause so much of a problem.
    I drove for 30 miles on a fairly flat freeway today. Just cruising at 60mph- 65mph and ended the trip at 58.3 mpg. I have about a half mile of surface streets so between a nice off ramp glide and some pulse and glide through the neighborhood the mpg jumped by about 1.5mpg. So there is definitely nothing wrong with the car. The nut behind the wheel is another story. :)
  2. Tideland Prius
    16,559
    lol. I just want summer. We were tempted with 59 degree highs on Tues and we just got dumped with 4 inches of wet snow. Ugh.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Not that our winters compare but we recently started seeing sunny days with temps in the 70s and I got all excited then it turned cold over night and the rain came back. Today was nice though. I'm wishing you warm weather, my friend. :)
  4. Patrick Wong
    18,210
    6,510
    F8L, it would be great if you could have your tire shop examine the interior of the 17" tires and figure out exactly what is wrong with them. I'm interested to know how many tires have a problem and what is the nature of the problem.
    If the fault is visible, please take sharp photos and post.
    You had reported that the tires hold air pressure and do not show sidewall bulging or other obvious damage. Since they were producing noise, maybe a tire was coming apart from within?
    From time to time an owner reports a sudden mpg decrease and the usual suspects don't produce any results. If you can document what is wrong with your tires, that will add new knowledge to the community!
    It would also be good to know how many miles had been logged on those tires at the time that the noise and increased drag started.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Definitely! I cannot afford new 17" tires right now or the near future but when I have the new ones installed I am going to have the tire shop look the old ones over and I'm going to take pictures or any damage we may find.
    I've had these tires since 2006 so they are a bit long in tooth even though they still have some tread left. I regularly swapped back and forth between the stock setup and the 17's because I can't stand the MPG drop but I love the looks and handling.
    My guess is either a tire is coming apart internally or I bent a wheel and it is not visible. Either way I will find out and document the issue as well as update the first page of this thread.
    Thanks for all your help, Patrick.
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Why are you running 17" tires on a a FE machine in the first place? Hal
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    If you're still having the RPM revving issue, maybe you can talk to peef and see if he can ride with you and run some techstream charts, graphs, etc. to see what is actually going on. Not sure if you two are close to each other, but pretty sure he's in CA (I know it's a large state, but never know). I'd offer, but you're 2000 miles away from me.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The difference in looks and handling are pretty significant. The handling is so improved that it feels like a completely different car. Taking 30mph curves at 60+mph is cake!
    The RPM issues are gone. I thought it may have happened after I swapped back to the 15s but I think it was due to the elevation change on a section of road. I appreciate your offer though. That's what I like so much about this forum. So many people willing to help each other out. :)
  9. Hal W
    Hal W New Member
    872
    53
    I was going to mention elevation change ,but thought better of it! <grin> Hal
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You're on top of things, as always. :D
  11. Tideland Prius
    16,559
    Thanks! I'm aiming for 60 with this car (was close last year) and maybe finally the rated 64mpg city next summer.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Finally got around to having my wheels and tires checked. I had them put on the balancing machine and its turns out one tire is starting to cup. They must have balanced it because when I put the wheels back on, the thumping noise and vibration is gone. The car drives like normal now. Maybe that wheel was way out of balance?
  13. bisco
    51,947
    they aren't nokians, are they?:D
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Nope. :)
    They are cheap Kumho Ecsta ASX. They are also 5 years old!
  15. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    So that was the problem all along?
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm afraid to answer that. It is really weird that an out of balance tire can cause those symptoms but it seems fine now. Crazy.
  17. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    It's interesting how much energy was being transferred/lost in that way
    Maybe you lost a weight after so long, especially if it was the self adhesive kind. Maybe it fell off mid-trip.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The weights are the adhesive type. I wonder if it was so off that it caused the cupping they mentioned. The thump was very pronounced.
  19. savrip
    savrip Junior Member
    56
    Louisville, KY
    I
    Glad to see your problem work out F8L. I'm having a similar issue, so it was interesting to read through your and look for a solution. Unfortunately I don't have one yet. My issue is ScanGauge II is reporting current MPG about 10MPG less then than the main display is. This is giving me 10MPG average lower, but compare it to the dash monitor and it appears to have no change. From process of elimination it would appear that the ScanGauge needs a reset. I unplugged it yesterday for several hours with no improvement. I guess I'll reset to default next and see if that helps. I wanted to check around and see if anyone else had been seeing this.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    My SGII was working well at the time and my dash display was in sync. Are you having the same problem with the tires going thump thump thump down the road? :)
