Need help..stuck..hah
Discussion in 'Gen 3 Prius Main Forum' started by RootBreaker, Jan 21, 2019.
  1. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    Ok just replaced all pads...all the way round. Started car and been pumping. No pedal. So whats the secret to abs brakes then?
    Thanks...
  2. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    All good. Weird crap... Was goin to floor then clunk. Said screw it. Threw in gear.. little bit in driveway... whey work great...weird. thx for the ear...
  3. Mendel Leisk
    42,044
    And no warning lights?
    After a test drive, apply/release the parking brake a few times, then raise the rear and check that the wheels spin fairly freely, go a revolution or two after you let go. Always a good check.
    amos and RootBreaker like this.
  4. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    Will do... gonna take a brake. Its 17f out...
  5. Mendel Leisk
    42,044
    Hah, plus 4C here, around 40F.
  6. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    Oh and what is weirder is i never noticed pedal is normally this way. Thus i saw no dash lights and said screw it.. lets drive around the development....
  7. Hopopotamus
    Hopopotamus Junior Member
    45
    Passaic, NJ
    Did you replace them because you had to or because you wanted? Also how many miles you have on the car?
  8. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    Dealership told me 10k miles ago i was at 3mm front and 4mm rear. Caution.. not required. My son drove his trailblazer to the metal so i sid.. lemme knock this out. In 18F weather... 20190122_051240.jpg
  9. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
  10. Mendel Leisk
    42,044
    Regardless of pad thickness remaining, you should be getting in every 3 years or 30K miles (Toyota US recommendation), just to clean them up and relube. You done good.
    RootBreaker likes this.
  11. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    I bet ive got many miles left. should have kept going.
    Dont want to dispose of these...
  12. Mendel Leisk
    42,044
    Save them for a decade, before chucking them out, then you'll feel better. No kidding, that what I do, lol.
    RMB and RootBreaker like this.
