Need help switching to lithium ion battery
Discussion in 'Gen 4 Prius Technical Discussion' started by SsrichiesS, Jun 17, 2022.
  1. SsrichiesS
    SsrichiesS New Member
    52,891
    i don't think anyone has done this
    Mendel Leisk and alanclarkeau like this.
  3. SsrichiesS
    I know there's no videos on it but I believe if I change the internal, I could makes it happen. I'm just worried if I open the lithium pack, it would void the warranty. So I have to make sure, I can do it. Haha
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No idea what country you're in - here, I'm certain you'd void the warranty - not just on the Battery - but also on the entire Computer/Electronics which ... could do anything. Different voltage, and power current characteristics. The charging system would be entirely different - LiION needs a Float Charge very different from a NiMH.
    You might also want to check with your Motor Transport mob - whether it meets the Design Rules - for fire safety, electrical safety and emissions.
    Why would you want to change it?
    You could talk to a HYBRID Specialist - they might have some clues.
    Doug McC, SsrichiesS and Mendel Leisk like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Yes, you will void the warranty, if you modify it. You should be able to open it since there are no seals on it, but make sure you put it together absolutely right and don't change anything.
    You could check with these guys (https://projectlithium.com). They have a Gen 4 version, but I would not make ANY changes till the warranty expires in another four years. And, according to the website, they are sold out now.
    I can't figure out why people use postal ZIP codes rather than just city and state. The ZIP sure tells people a lot more about you than the city and state.
    ZIP Code 92234 Map, Demographics, More for Cathedral City, CA
    #5 jerrymildred, Jun 18, 2022
  6. Mendel Leisk
    42,376
    Zip code is a very US-centric locator, cryptic as heck, and leaves international readers scratching their heads.
    alanclarkeau, jerrymildred and bisco like this.
  7. bisco
    52,891
    even us. i had no idea it was a link until someone told me
