Need help to find LED relay for my 2015 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jHUYNH9, Oct 25, 2015.
  1. jHUYNH9
    jHUYNH9 New Member
    Elk Grove
    Hello all,
    I need help to find a LED relay for my 2015 Prius (to prevent hyper blinking). I ended up purchasing one using a link in one of the mod threads. After receiving it and trying to install it. I found out it's for a 2010-2013 model. I've been trying to search online but cannot find one for my 2015. Any help to locate where I could purchase one would be much appreciated, thanks!
    Left green one is from my 2015 model, right is the incorrect 2010-2013 model.
    #1 jHUYNH9, Oct 25, 2015
  2. Mendel Leisk
    42,376
    What is "hyper blinking"?
  3. jHUYNH9
    jHUYNH9 New Member
    Elk Grove
    When replacing turn signal bulbs with LED versions it causes the signal light to blink at twice the speed, like when the car knows you've got a turn signal that's out.
  4. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    Maybe try a wrecking yard?
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
  6. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Flasher relay is the same for 2010-2015 (actually, the same for all generations of Prius so far). Looks like you pulled the wrong relay.
    jHUYNH9 likes this.
  7. jHUYNH9
    jHUYNH9 New Member
    Elk Grove
    Yes it looks like I pulled the wrong relay. I went looking for a green one when its blue. Thank you!
  8. Vman455
    540
    556
    The Middle
    No problem! Did you go with a generic LED flasher or the Tapturn? Its user-customizable features look pretty cool.
  9. jHUYNH9
    jHUYNH9 New Member
    Elk Grove
    I went with the generic. I'm not fancy :D
    Accordlayingkit likes this.
