Need help Warning lights on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josephphamy, Mar 2, 2017.
  1. Josephphamy
    Josephphamy Junior Member
    43
    Long Beach CA
    My daughter has a Prius 2005, 170K miles. Please help me to troubleshoot the warning light error. Thank you so much
    these are the codes:
  2. Patrick Wong
    18,210
    6,517
    The major issue appears to be a high voltage ground fault. This may be due to an electrolyte leak in a battery module. It also might be due to a failed stator winding in the transaxle.
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    C1241 – Do you have the detailed code? Probably it’s just bad/empty 12V battery. But this does also mean that other codes are not as reliable because Prius can generate random codes with bad 12V battery.
    C1242 - Do you have the detailed code? Maybe this could be caused by bad 12V battery.
    C1310 – This is just caused by other code(s)
    U0293 – Commonication problem between HV ECU and ECM. Wiring or either of those control units. Maybe a small change that this would be caused by bad 12V
    C1259 – This is just caused by other code(s)
    P0AA6 – Has AC been filled with gas that has wrong oil? Or even using equipment contaminated by wrong oil? Prius uses ND oil rather than PAG oil. Or maybe there has been water in the hybrid battery? Water in the back might also cause corrosion in connectors that leads to U0293. If it’s not either one of those it could be your transaxle.
    Check the 12V battery first and while at it you see if there has been water in the areas of 12V battery, spare tire and hybrid battery. Detailed code is under freeze frame data on Techstream (which is cheap and good diagnostic tool as Mini-VCI) but probably you should be able to find it with your tool as well.
  4. Josephphamy
    43
    Long Beach CA
    20170303_113831.jpg 20170303_130537.jpg 20170303_113837.jpg 20170303_133917.jpg 20170303_133920.jpg 20170303_113831.jpg 20170303_130537.jpg 20170303_113837.jpg 20170303_133917.jpg 20170303_133920.jpg
    Hi Patrick. Thank you. I see the case has the sign of leaking but I inspected one by one battery, don't see any leak. How do i check if individual cell is leak or good? Few months ago when I replaced the cell, I accidently dropped 1 cell to the floor from 3 ft high but did not mark which one. I also see all of the battery terminals are corroded, would you please explain what causes this? and what is the best chemical to clean these terminals? . And I almost forgot to mention that I lost 2 screws holding the cell down to the chasis, is that matter? ..Please help.
  5. Josephphamy
    43
    Long Beach CA
    Hi Valde3. The 12V battery is OK, the factory label is 05/15 and I bought it from Toyota dealer, Voltage checked OK. No water or sign of water in the back, nor battery compartment. We did not changed oil before it had problem and we used Mobil 1 for engine oil since we had the car. We did not refill any gas to the AC. Only problem found as Patrick Wong mentioned is the hybrid battery leaks and I don't know what best technique to check for leak on indivudually cells. ! waiting for the help from this forum. Thank you. Joseph.
  6. Patrick Wong
    18,210
    6,517
    The electrolyte is clear and not very visible. You would have to assume that at least one module adjacent to case corrosion is leaking sufficiently to reach the case bottom. If you see corrosion on the busbar hardware, that may partly be related to module electrolyte leakage.
  7. Josephphamy
    43
    Long Beach CA
    Sorry to ask.. What is the "Bus bar"? is the plate connecting the terminal (+, -) from cell 1 to 28? If the module is leaking, can I tell if I buy a charger/ discharger to determine the cell is good or bad? Hope to hear from you soon.
  8. Josephphamy
    43
    Long Beach CA
    I cleaned the contact 20170304_120056.jpg plates with vinegar, baking soda, replaced 2 cells that had the sign of leaking. Will see if the problem is fixed!
  9. Josephphamy
    43
    Long Beach CA
    Please help. The problem is not fixed. i drove about 20 miles, the Triangle and the Engine light came on.
  10. bisco
    52,849
    any codes? are you using mini vci?
  11. Josephphamy
    43
    Long Beach CA
    last time I had to bring to the shop to read the code. This time I have not read yet. I am ordering the mini VCI today and will update when I have the code. thank you. joseph
  12. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
  13. Patrick Wong
    18,210
    6,517
    The traction battery has two bus bars, which are the plastic strips containing the copper pieces that you cleaned.
    You need to distinguish between two issues: 1) electrolyte leakage and 2) whether the module will accept a charge. It is possible for a leaking module to still be functional as a battery, however if either of those issues exist you need to replace the module.
    And even after going through all that work, if the OP leaves leaking modules in the battery case, then the problem will eventually recur.
    valde3 likes this.
  14. Josephphamy
    43
    Long Beach CA
    20170314_141028.jpg 20170314_140837.jpg Hello Everyone,
    I finally got the mini VCI working. And I got the codes on the attachment. I don't know what to do now. Please help! View attachment 126111
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    I doubt this is the problem, but If it hasn't already been replaced now would be a good time to change the transmission fluid.
  16. Patrick Wong
    18,210
    6,517
    Each ECU can log its own DTC. What DTC are logged by the hybrid vehicle ECU and the traction battery ECU?
  17. Josephphamy
    43
    Long Beach CA
    I took to the shop to change the transmission fluid with Toyota Fluid (before my 1st post)..
  18. Josephphamy
    43
    Long Beach CA
    Hi Patrick. I don't understand, would you please explain what it means I appreciate it. Thanks
  19. Patrick Wong
    18,210
    6,517
    The Prius has multiple electronic control units (ECU). Each ECU can log diagnostic trouble codes (DTC). The first photo you posted shows DTC logged by the skid control ECU while the second photo shows DTC logged by the gateway ECU.
    Although those codes are interesting, what you need is to see what DTC are logged by the hybrid vehicle ECU, traction battery ECU, and engine ECU. Any such codes will help to determine the root cause of your car's problems.
    valde3 likes this.
  20. Josephphamy
    43
    Long Beach CA
    Hi Patrick. Where do i get that log? I am new to the techstream, I was trying to look for it this morning but I can't find it.
    Thank you
    BTW, are you in South CA? May I PM you?
