Need help Warning lights on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josephphamy, Mar 2, 2017.
  1. ChapmanF
    19,019
    What Patrick was getting at, the two screenshots you posted in #14 are, one from the ABS/VSC/TRAC computer (ECU), and one from the Gateway ECU. (You can see those names in the tabs near the top of the screen).
    If you just run a Techstream 'health check', you should get back a whole list of ECUs and whether they have any active codes or not.
    In your screenshots, the first one, from the brake computer, is just telling you that it has heard of some problem from the HV computer. Those two computers have to share information, because if the HV one is having some problem, the brake computer has to know it might be on its own to slow the car down without regenerative help. So it has those two codes, but they are pretty vague. All they mean is "hey, I'm the brake computer, and I've heard the HV computer mention there's some problem."
    So to track down the problem, you need to check the other ECUs that are showing codes in Techstream. (Don't be too strict about the names of the ECUs ... the one that basically coordinates the powertrain was called "HV ECU" in Gen 1, they haven't used the exact same name in all gens, could be called something like Hybrid or Power Control, I don't have the books in front of me right now.)
    Your second screen shot is from the Gateway ECU (as its name suggests, it sits at the junction of some different comm networks in the car, and passes data between them), and all three of those codes are showing trouble communicating with three different other components in the car.
    Those codes might be clearable (try asking Techstream to clear them). Sometimes, connecting odd scantools or devices to the OBD port can cause comm errors to be logged, and you can clear them once the offending devices aren't connected.
    -Chap
    Patrick Wong likes this.
  2. Patrick Wong
    18,210
    6,517
    Maybe the DTC from the "important" ECU's are not visible to the OP because of the comm faults...
  3. ChapmanF
    19,019
    The Gateway ECU seemed to be complaining only about the Body, Smart Key, and Combination Meter ECUs.
    A Gen 2 has three types of network: the CAN, the BEAN, and the AVC-LAN; the Gateway ECU has an interface on all three (2004 New Car Features, p. BE-47). The Body, Smart, and Meter ECUs are all on the BEAN (p. BE-49). The HV and battery ECUs are both on the CAN (p. BE-48), which has its own direct connections to the DLC connector, so the reported comm errors shouldn't be interfering with talking to them.
    So, I'm not sure why the OP isn't seeing those codes. Maybe just spend a bit more time getting familiar with Techstream?
    Also not sure yet what might explain those particular three BEAN denizens not showing up. The BEAN is a ring network, intended to stay functional even with any one break. Page BE-49 shows where those ECUs are, logically, around the ring, and they aren't all three adjacent, scuttling my easiest guess. Back to the drawing board....
    -Chap
  4. Josephphamy
    Josephphamy Junior Member
    43
    Long Beach CA
    Hi. Thank you for your help. I ran the techstream again today. My Laptop died just got it fix.
    1st screen is
    i Clicked on the Hybrid Control: Code P0AA6 showed up 1491330529726326039649.jpg
    I clicked on the Code:
    I went back and clicked on the Engine and ECT:
    And Gateway:
  5. Josephphamy
    43
    Long Beach CA
    And this is the data list. Please help us. My Daughter does not have a car for month now. Thank you
    14913311572751548275623.jpg 14913312265031068870412.jpg 14913312265031068870412.jpg
  6. Patrick Wong
    18,210
    6,517
    1. P0AA6 is accompanied by a three digit info code. See if you can find that.
    2. Worst case, just disconnect the 12V battery for a few minutes, then reconnect. The car can be driven once after that. Repeat that process while you continue to research the problem and decide what to do about it.
    Paul Schenck likes this.
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    The third photo above show detail codes 526 and 612--ground fault in the battery.
    Patrick Wong and JC91006 like this.
  8. Patrick Wong
    18,210
    6,517
    OK, that implies at least one battery module is leaking electrolyte.
  9. Josephphamy
    43
    Long Beach CA
    Thank you for your inputs from all of you. How do I tell what cell is leaking? I checked Voltages but I did not know how to check for leaking. I replaced 2 cells, they were nearly 8 volts but on the chassis near those cells had the sign of corroded. If I buy a Charger/ Dischager to charge and discharge to compare the discharging time to one another.. Will the leak battery show differently?
    By the way, I had a little code check bought from Harbor Freight to clear the code, but only do that to move the car for street cleaning. Sometime it last for a week before the error Red triangle came back, sometime code comes up in 5 mins driving, few times I drove 25 mins to 30 mins on freeway to test drive, it was fine, but exiting the freeway, stops at red light code came up.
    Joseph
  10. JC91006
    16,936
    8,647
    The battery will usually leak at the battery terminals. Look for wetness on the terminals.
    That corroded case might need to be cleaned or replaced
  11. andrewclaus
    993
    326
    Golden, CO
    And if you find it, treat it with care. From what I've read, the leakage is caustic and can be neutralized with a weak acid like vinegar. Use chemical protective equipment for eyes and skin, and ventilate the area well.
    Be sure to properly torque any terminal nuts you disconnect. Look up proper ratings and use a small torque wrench, in in-lbs.
  12. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    And to do the job properly, you need to disassemble the battery and discard any leaking modules. Clean and dry (thoroughly) each module and also clean the inside of the case. Ensure the modules and case are rinsed of the cleaner and the they are thoroughly dry before reassembling. Because the electrolyte is clear, it can be hard to see the contamination, so clean all modules, but certainly all that are adjacent to the leaking modules.
  13. Josephphamy
    43
    Long Beach CA
    20170425_095542.jpg 20170425_095530.jpg 20170425_095525.jpg Hello Everyone
    I have been clearing the code and used the car, because I can not find where the problem came from.. Clearing the code sometime lasts for 1 day, sometime 3 days, sometime code came up in 10 mins drive. I opened the battery pack again today and found few cells leaking something like oil, other cells has some " white powder " on the case. When the cells leak they show " white " or " oil ? at the terminals are clean. what should I do? how do i tell which one is bad? or I have to replace all of those cells? , approx 8 cells in those area. Please help us. see new photos Thank you. Joseph
  14. JC91006
    16,936
    8,647
    The "wet" modules are the leaking ones. The "white" module residue is just dried corrosion, that should be cleaned off.
    The leaking modules should drop voltage faster than the good modules. Record the voltage and wait a week and take the voltage readings again. The leaking modules voltage should drop much faster than the good modules.
    There's so much acid on the battery case, I suggest you buy yourself a new case and reassemble. You shouldn't be reusing that case.
    If you have the funds to buy 8 newer modules, I would buy 8 and be done with it. Keep the other ones as test modules or spares.
  15. Josephphamy
    43
    Long Beach CA
    thank you. I will order some cells from Ebay tonight.
  16. JC91006
    16,936
    8,647
    Do you have equipment to charge and balance the pack?
    SM-N900P ?
  17. Josephphamy
    43
    Long Beach CA
    I am thinking to get one from Ebay selling for Remote control Car.. What is a good, affortable model do you recommend?
  18. Josephphamy
    43
    Long Beach CA
    I have changed total 7 cells in the past. I havr 2 options: If I buy 8 more x 40 = 320. or buying whole pack from a local guy selling a refurbished.. with 1 year warranty for $800. I just go to pickup and exchange, no labor. If option 1, I spend 320 to buy 8 cells I still have to deal with those 13 original 12 years old cells can break down anytime. And buying one by one, the sellers don't pack well, carrier does not handle with care, exessive shock might cause internal broken and leak again.. We have kids in college and this car is for my daughter, we just want to save money for them.. I still dont know what is best way I should do.. If buying whole pack will it fix the problem? From those error codes, what do you think .? Any suggession, wrong or right, good or not are appreciated.. I undertand that Electric Hybrid is very difficult. please give me some inputs. Thanks for reading my post and helps. I am waiting for your advice before buying cells or whole pack..
    Joseph.
  19. JC91006
    16,936
    8,647
    Who's the local guy for $800? You can get that price at salvage yards....
    SM-N900P ?
  20. JC91006
    16,936
    8,647
    You should definitely for $800 for a reliable battery. This whack a mole thing isn't working for you
    SM-N900P ?
